Valve Rocker Arm - BMW Forum - BimmerWerkz.com
Old 04-28-2003, 11:23 AM   #1 (permalink)
will is an unknown quantity at this point
Just got a question guys. I got a 1984 BMW 325E. one of my rocker arm for my valves is worn out and it's making a ticking noise on the car. ANd it seems like in order to replace that I have to take the whole engine head off because all the rocker arms are attached to a BAR. Does the whole head have to come off? or is there an easier way? Thanks in advance.
will is offline   Reply With Quote
Old 06-10-2004, 05:34 PM   #2 (permalink)
87325iTAYLOR is an unknown quantity at this point
Have you had any ideas returned to you on this problem? I would like to know if that is the case. Thanks.
87325iTAYLOR is offline   Reply With Quote
Old 06-11-2004, 12:03 PM   #3 (permalink)
will1506 is an unknown quantity at this point
Send a message via ICQ to will1506 Send a message via AIM to will1506 Send a message via MSN to will1506 Send a message via Yahoo to will1506
not sure how I reposted that by accident or did I even do it. But I got rid of the 84 325e a while ago and picked up a 1991 318i a little weaker but a lot less problem.s
will1506 is offline   Reply With Quote
Old 04-28-2005, 12:07 AM   #4 (permalink)
ae.cowboy's Avatar
ae.cowboy is an unknown quantity at this point
[snapback]4037[/snapback]
hey, if you ask a BMW tech, they will tell you that you have to pull the head off, but I think it can be done w/o doin that by just dropping out the radiator and pulling your rocker shaft out of the front of the car. That could be tricky though if any of the rocker arms want to stick to the shaft... its up to you.
1986 BMW 325
**Full custom 2 1/2 exhaust, no cats**
**Chipped***
**Member of the Lone Star Club**
**Member of the Ticket for Passing on Left Shoulder Club**
(I actually got that ticket dismissed lol)
ae.cowboy is offline   Reply With Quote
1998 318is - Adjusting valve gear? alex_318is 3-Series (E36) 3 09-18-2005 04:48 PM
Valve Question mrclean 1,6,7,8 - Series and Mini Cooper 2 06-16-2005 09:29 AM
Governor Valve TrannyTrubl 3-Series (E21, E30) 2 05-24-2005 07:16 AM
Eccentric Cam On Rocker Arm ae.cowboy 3-Series (E21, E30) 0 03-30-2005 08:51 PM
318ti ABS Hydraulic valve resistor readings retirednow 3-Series (E36) 0 06-08-2004 08:29 PM
