Valve adjustment how-to for an '81 320i? - BMW Forum - BimmerWerkz.com
Old 03-02-2008, 11:56 AM   #1 (permalink)
UncleMike's Avatar
Car: 1981 320I
UncleMike is on a distinguished road
Been searching around the forums, but not finding what I'm looking for. Has anyone posted a nice write-up on tips, tricks and pitfalls, or even a step-by-step for checking and adjusting the valves on an e21 320i? How about checking if they need to be adjusted?
Any help greatly appreciated.
Thanks,
/Mike
UncleMike is offline   Reply With Quote
Old 03-02-2008, 02:35 PM   #2 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
Thanks,
/Mike
1. Disconnect necessary components noting installation position, then remove cylinder head cover.
2. Rotate crankshaft using suitable wrench or remote starter, until No. 1 cylinder is at TDC on compression stroke. Always turn crankshaft in normal direction of rotation.
3. Check clearance of No. 1 cylinder intake and exhaust valves, inserting suitable feeler gauges between tip of valve stem and rocker arm. Valve clearance for intake and exhaust should be:
Cold [1] 0.20mm (0.008in)
Hot [2] 0.25mm (0.010in)
NOTE : BMW provides both hot and cold valve clearance specifications but does NOT recommend hot valve clearance adjustment.
4. If clearance is not as specified, adjust as follows:
a. Loosen adjusting cam locknut on side of rocker arm.
b. Rotate adjusting cam on tip of rocker arm to obtain specified clearance.
c. Hold position of adjusting cam and torque locknut to 6.5 to 8 ft. lbs.
d. Check clearance.
5. Continue rotating crankshaft until each cylinder in firing order is at TDC on compression stroke, checking and adjusting valves for each cylinder as outlined in step 4.
BMW Technician
dvmotorsports is offline   Reply With Quote
Old 03-02-2008, 02:39 PM   #3 (permalink)
UncleMike's Avatar
Car: 1981 320I
Can't really ask for more than that.
Thanks,
/Mike
Old 03-02-2008, 02:47 PM   #4 (permalink)
Thanks,
/Mike
courtesy of alldata
BMW Technician
Old 12-23-2009, 12:00 PM   #5 (permalink)
M10er is on a distinguished road
Exclamation e21 valve adjustment
I remember seeing that you want to check clearances again after 600 miles:
somewhere (going to find) once saw a great page/site with captioned pics, I'll get back to yooz
M10er is offline   Reply With Quote
635CSi M30 Valve Adjustment advice??? AlpineSixAndSeven 1,6,7,8 - Series and Mini Cooper 0 12-21-2007 09:35 PM
1 person Valve Adjustment... Ideas? 325eXTATIC 3-Series (E21, E30) 17 09-21-2006 02:35 PM
4cyl valve adjustment?? Moosepuck 3-Series (E21, E30) 22 05-30-2006 07:06 PM
valve adjustment? Trob 3-Series (E21, E30) 4 09-12-2004 07:11 PM
Valve Adjustment on 89'325i jdpiper 3-Series (E21, E30) 1 01-13-2004 07:49 PM
