valeo alternator / inconsistant voltage - BMW Forum - BimmerWerkz.com
Old 11-08-2009, 02:45 AM   #1 (permalink)
tim96 is on a distinguished road
i have a valeo alternator in my e30 320i. On some drives it works fine but other times my all my lights strobe e.g voltage goes up and down up and down. Bad voltage regulator i suspect? belt is tight could anything else cause it is there a way to test it. I put a volt meter across the battery and the voltage is nt constant so i guess it is the regulator (12.5 - 15.5v) for memory not sure but it did reach 15 +.. volts
Reading around on the forums this is easy to change on the bosch alternator but i cant find info on how to change the voltage regulator in the valeo
or is it better to just replace the whole alternator? if so would a bosch alternator fit?
tim96 is offline   Reply With Quote
Old 11-08-2009, 09:15 AM   #2 (permalink)
Some auto parts stores will do an electrical check for free. My first guess it the voltage regulator.
alternator/battery/voltage WardJ 3-Series (E21, E30) 0 11-22-2005 07:03 PM
Voltage Stabilizer 328I99E46 3-Series (E46, E90) 2 03-05-2005 08:51 AM
Valeo Vs Bosch Alternator, 105 Amps. agtur2001 3-Series (E36) 3 12-14-2004 10:53 AM
Where Is My Voltage Regulator Located? agtur2001 3-Series (E36) 5 12-09-2004 05:51 PM
Completed my Valeo to Bosch alternator conversion MOTRSPRT 3-Series (E36) 5 01-26-2004 06:16 PM
