To V12 Or Not To V12, That's The ??? - BMW Forum - BimmerWerkz.com
Old 06-09-2005, 06:52 PM   #1 (permalink)
fporro is an unknown quantity at this point
Send a message via MSN to fporro Send a message via Yahoo to fporro
well, so today ran into a non body damaged 12/88 750iAL
that engine looks humoungous !!!
here's some specs... Output (HP) 300 @ 5200
was told that those heads usually warp, shoul i pull it anyways ???
yet, size = more weight, the dilema :rolleyes
cheers,
Frank
e30 parts
fporro is offline   Reply With Quote
Old 06-09-2005, 07:33 PM   #2 (permalink)
Got any way to test run it?
Old 06-09-2005, 07:43 PM   #3 (permalink)
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
Its been done before, but you would have to do some nice suspension work. The power you are gaining is not worth the weight the engine is going to add to your car, you will lose that E30 feel.
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 06-09-2005, 11:51 PM   #4 (permalink)
offabroadway is an unknown quantity at this point
As enticing as this prospect is, the extra weight in the front will make the car handle like a front driver, and without any weight out back in the twisties, will make it squirrelly and all too happy to hang out the tail.
On a drag strip, great. But honestly, just drop an 8cyl in there if you really want the bigger engine, or just hop up your six.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 06-10-2005, 01:05 AM   #5 (permalink)
9x16's Avatar
9x16 is an unknown quantity at this point
sounds all good,but that engine is way too problematic and heavy for the e30.
89'325i(4door)
FK HiTec springs
Tokico HP shocks
Brembo X drilled rotors
PBR pads
Black hella's
K&amp;N intake
Chip
AC Schnitzer styling(interior)
9x16 Remotec wheels
AC Schnitzer strut bar
Remus catback
9x16 is offline   Reply With Quote
Old 06-10-2005, 11:37 AM   #6 (permalink)
DJProfessor's Avatar
DJProfessor is an unknown quantity at this point
yes yes..........
that is my next swap i would love to get my fingers on........
you will have to have a custom header fabbed up and also plan on cutting into the car in places to get it all to fit. it is a project for sure........
but they are all correct about the weight distribution, that arse will become super sloppy......however......lighting up an E30 off the line and around corners would look rather funny, esp. if you left/put 318i badges on it
sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
DJProfessor is offline   Reply With Quote
Old 06-10-2005, 06:23 PM   #7 (permalink)
[snapback]352262[/snapback]
I agree she would be nose heavy and hey, it is tough enough to work on the M70 in a E32 engine compartment let alone a E30. As to problematic, my 1988 750 has 200,000 miles on her and she runs great and uses no oil.
Old 06-11-2005, 08:29 AM   #8 (permalink)
Go to vRoadfly.com and then the E32 messge board. there is a post there by KW90735il that will lead you to a E32 data site and at that site is a piece on putting a v12 into a E30 as well as a picture of the V12 in a E30.
Old 06-11-2005, 09:37 AM   #9 (permalink)
e36_m3_Turbo's Avatar
i would rather do a s62(e39 m5 engine) swap 400hp v8
No longer red.
Old 06-11-2005, 09:49 PM   #10 (permalink)
Originally posted by witeshark+Jun 9 2005, 06:33 PM--><div class='quotetop'>QUOTE(witeshark @ Jun 9 2005, 06:33 PM)</div><div class='quotemain'>Got any way to test run it?*
[snapback]352169[/snapback]
[/b]
unfurtuanetly not, both ECU were gone.
Originally posted by Bmw1990@Jun 9 2005, 06:43 PM
Its been done before, but you would have to do some nice suspension work.* The power you are gaining is not worth the weight the engine is going to add to your car, you will lose that E30 feel.
[snapback]352173[/snapback]
i'm done with the suspension set up, she's running on rails
i sure don't want to loose the e30 feel.
a while ago removed A/C, dryer and condensor, then removed the counterwight on back. here's My suspension setup
Originally posted by offabroadway@Jun 9 2005, 10:51 PM
As enticing as this prospect is, the extra weight in the front will make the car handle like a front driver, and without any weight out back in the twisties, will make it squirrelly and* all too happy to hang out the tail.
[snapback]352235[/snapback]
so true, last thing i'll do is upgarde the engine, so far did the basics and my sentiments are ...
- hot air intake K&N cone filter
- big six afm used
- 5.0 injectors
- # 173 ecu
- JC chip :P
- Accel coil
thanks 9x16, as always contructive advise
Originally posted by DJProfessor@Jun 10 2005, 10:37 AM
yes yes..........
if you really want it then ir's in Sun Valley, CA ...Pick A part yard.
you will have to have a custom header fabbed up and also plan on cutting into the car in places to get it all to fit.* it is a project for sure........
but they are all correct about the weight distribution, that arse will become super sloppy......however......lighting up an E30 off the line and around corners would look rather funny, esp. if you left/put 318i badges on it*
[snapback]352363[/snapback]
<!--QuoteBegin-e36_m3_Turbo
@Jun 11 2005, 08:37 AM
[snapback]352641[/snapback]
[/quote]
400 HP's , wahhh :nana
In all, i'm going to pass and enjoy the summer on local twisties
thanks all for the advise
If anyone wants it, is located at Pick A Part in Sun Valley, CA
cheers,
Frank
e30 parts
Old 06-12-2005, 08:15 PM   #11 (permalink)
ahh to be back in good ole Cali....... ghead
seeing how i am becoming the reluctant owner of another E30 i will have to keep my eyes peeled back here for one........
Old 06-14-2005, 01:17 AM   #12 (permalink)
I second the M5 engine option. It's been done to an E46 (Hartge E46 V8 conversion, appeared in Car & Driver very late last century, anyone remember?) and would provide better power, less weight and fuel consumption, and just generally a better experience. Yes, more weight would be involved, but shaving those useless extra 4 cylinders off there saves you in weight, not to mention size (its difficult enough working on the M20 in there, I wouldn't want to picture anything longer in it's place... the V8 would actually be shorter, just wider is all).
Now the problem becomes getting your hands on an unmolested M5 engine without shelling out megabucks.
Old 06-14-2005, 01:25 AM   #13 (permalink)
ummmm the e39 is more a smaller engine i think overall in size. i dont know the exact dimensions of both engines, but the s62 produces more hp, and most likey has more mods for it too. just my opinion, it is a lot of grunt to tackle in such a small car. but can and has been done. both ways.
No longer red.
2006 Brabus CLS V12 S Rocket bmwcrazy Other Rides 25 02-14-2006 03:44 PM
5.0 v12? Byron320i 3-Series (E36) 3 10-13-2005 07:08 AM
V12 engine swaps?Whats out there? Denv12 1,6,7,8 - Series and Mini Cooper 1 09-06-2005 09:02 PM
Damn That's Nice... jze325i 3-Series (E21, E30) 19 04-20-2005 08:15 AM
