Urgent! what is Lambda Control #1 - BMW Forum - BimmerWerkz.com
Old 05-29-2004, 12:35 PM   #1 (permalink)
brycealicious is an unknown quantity at this point
Hi all.... My car won't start and I need it to work, like NOW. I check the fault codes a nd got 1222 for Lambda Control #1. What the hell is that. I have been having problems getting it stated latly but it usually goes after one or two tries...
PLEASE HELP> I"M a mess without my car.
Bryce.
brycealicious is offline   Reply With Quote
Old 05-29-2004, 01:10 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Its your O2 sensor control. Sounds like there may be something wrong with the engine DME(computer).
My M50 Powered E30 Page
Old 05-29-2004, 01:21 PM   #3 (permalink)
Ok,
Engine DME control... can I fix that myself?
and the o2 sensor it probably shot but the car usualy starts anyways...
what can i do to get it going?
Old 05-29-2004, 01:59 PM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I doubt you can fix the computer yourself. Unless you have that sort of testing equipement for printed circuit boards and knowledge. You can try going to a junkyard to find a new computer, just bring yours with you cause if the #'s don't match it won't work. Another opition is to have someone with a car just like yours put their computer in your car and see if it fires up. If it does either get a junkyard computer that matches yours, or get a new/referb one. At my work we use ProgRama brand and haven't had any problems with them. http://www.programainc.com/
Old 05-29-2004, 02:37 PM   #5 (permalink)
great, where is the computer on the car anyways... and what else could my problem be? could the o2 sensor cause the car to not start at all? or the computer could cause that problem? Like I said earlier, the car is givving me a 1222 eror code. Could that be the cause?
Old 05-29-2004, 03:15 PM   #6 (permalink)
takaaco's Avatar
takaaco is an unknown quantity at this point
Send a message via Yahoo to takaaco
the computer is under the plastic trim on the top of the glovebox
[<img src='http://www.bmw-forums.com/forum/index.php?act=Attach&amp;type=post&amp;id=12968/signature.jpg' border='0' alt='user posted image' />
takaaco is offline   Reply With Quote
Old 05-29-2004, 03:43 PM   #7 (permalink)
ok,
followed my repair manuelles guide to testingthe computer and all seems well. So could te 1222 error code be the problem? I don't get why the engine would not start because of the o2 sensor? I also took apart the air intake and cleaned it out, no problems there. maybe the injectors or the cold start valve? please help! I have put so much money in this car in the pat month it's not even funny! thanx
Old 04-15-2008, 10:54 AM   #8 (permalink)
quality
Delmarco's Avatar
Bryce.
Its your air/fuel mix flowing throw the system. But it can be anything from O2 sensor to you need to put better octane gas in your car.
Old 04-15-2008, 11:05 AM   #9 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I hope he figured this problem out 4 years ago...if not, I'm sure he got rid of the car by now...
yammahamma is offline   Reply With Quote
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
Need Advice On Control Arm Replacement RC-Atlanta 3-Series (E36) 1 03-02-2005 04:58 PM
Traction Control bigred318 3-Series (E36) 14 12-20-2004 05:47 PM
What the hell is LAMBDA Control #1 jrhaile 3-Series (E36) 8 09-09-2004 05:43 AM
