Upgrades OPTIONS - BMW Forum - BimmerWerkz.com
View Poll Results: What should I do?
Sway Bars 1 5.26%
Cams and Piston Heads 0 0%
Re-Gear 1 5.26%
New Exhaust 3 15.79%
Chip 9 47.37%
Shocks 3 15.79%
Springs 2 10.53%
Voters: 19. You may not vote on this poll
Old 02-05-2004, 10:57 PM   #1 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
I need some help on what I should do to my car, i estimate that each thing, thought out thoroughyl, costs a little under 500$ for each choice, which is about how much I have to spend. Please take it seriously, and what would be an actual good improvement to the car. Thanks!
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 02-05-2004, 11:02 PM   #2 (permalink)
e36_m3_Turbo's Avatar
i meant to vote on chip but i voted on exhuast. oops
No longer red.
Old 02-06-2004, 05:53 PM   #3 (permalink)
ragehardintothebendies is an unknown quantity at this point
I chose shocks as tires or driving school were not on the list
ragehardintothebendies is offline   Reply With Quote
Old 02-06-2004, 06:54 PM   #4 (permalink)
i chose shocks too. get some koni sport adjustables order from ground control to get the top adjustable rears
Old 02-07-2004, 09:57 AM   #5 (permalink)
{NTM} is an unknown quantity at this point
Send a message via MSN to {NTM}
I choose new exhaust because it made a big differiance if your exhaust is not i good shape. I have change my this week and what a fun i have now -=)
But if is your exhaust is nice...umm the chips will do a nice power upgrade -)
BMW 325IX Black, Build for drift
{NTM} is offline   Reply With Quote
Old 02-08-2004, 11:59 AM   #6 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
I voted for a chip, but shocks were not too far behind. I think they both add to the fun factor. Let us know what you decide on.
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Old 02-25-2004, 12:41 PM   #7 (permalink)
tourist101 is an unknown quantity at this point
If sway bars are anti roll bars, then the standard eibach kit uses exactly the same size diameter as your 325is, so its really worthless. you'd need M3 (but there weld in) anti roll bars.
go for the cylinder head and cam.
tourist101 is offline   Reply With Quote
Old 02-25-2004, 01:38 PM   #8 (permalink)
Silver4evr's Avatar
Spiff325is....what was your choice and have you done anything yet?
Old 02-25-2004, 03:05 PM   #9 (permalink)
no they arent. the M3 has the front mounts welded to the struts, but the actual sway bar is 1mm thinner than the 325i bar, and you can use the 325 sway bar with either setup. the biggest front sway bar is 21mm found in the cabrios for the rear, the M3 sway bar is only 1-2mm thicker, and would be a direct swap. the most popular aftermarket sways are Eibach, ST, and Ireland Engineering, and all would need to have rear reinforcement mounts bolted or welded under the trunk to support the thicker rear bars.
Old 02-25-2004, 04:20 PM   #10 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
I ended up getting a nice UUC Short SHifter with an M shift nob. Its realy nice, and i Had my control arms, shock mounts, and bushings replaced so its running like a champ on roids. It really is nice now, the shift throw is like 3 inches, its so nice. Thanks for the input, it really is appreciated. Though I wanted to get a chip and stuff, something to increase HP didnt seem to appealing to the parental, so I went with the short shifter. THANKS A BUNCH :P
Old 02-25-2004, 04:22 PM   #11 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
here is a little pic of what I got
Old 02-25-2004, 04:22 PM   #12 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
the nob..it isnt a good pic, you really have to see it and feel it
Old 02-25-2004, 04:40 PM   #13 (permalink)
Silver4evr's Avatar
Good drivin' to ya!
Old 02-25-2004, 05:49 PM   #14 (permalink)
good choice. how much was it?
Old 02-25-2004, 10:08 PM   #15 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
195.95, and whats suprising, is I actually got it in like 2 days, usually UUC ships their shit in like 4 months, but Bimmertoys.com is a real good place to shop
first next last upgrades theironm0nk 3-Series (E36) 5 09-25-2005 02:09 PM
Best Performance Upgrades? matt719 5-Series (E12,E28, E34, E39, E60) 4 10-24-2004 12:44 AM
What upgrades are best? sre2114 3-Series (E36) 22 08-29-2004 09:42 PM
Performance Upgrades dubes1982bmw320i 3-Series (E21, E30) 37 08-12-2004 04:54 PM
upgrades spiff325is 3-Series (E21, E30) 29 04-24-2004 08:42 PM
