Turn Signal And Back Light Issues - BMW Forum - BimmerWerkz.com
Old 02-15-2005, 03:49 PM   #1 (permalink)
bmwbob is an unknown quantity at this point
1988 325-RF turn signal intermittant. Changed bulb, cleaned all contacts-will work for 30 seconds then quits. Rear lights flash rapidly with front out-OK with front working. Emergency flashers don't work. Will bad flasher switch cause this problem only on 1 side? Left works fine. Also, where is chasis ground for turn signal-above brake pedal?
Other issue-warning lights in overhead for licence plate and rear loghts come on often with lights working fine. Is the sensor in the trunk for these?
bmwbob is offline   Reply With Quote
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 06:48 AM
Fast Blinking Right Hand Turn Signal BMWDriver86 3-Series (E21, E30) 10 01-21-2005 11:48 PM
Turn Signal Harness jnfitness 3-Series (E46, E90) 0 11-26-2004 05:34 PM
left turn signal white 330ci 3-Series (E46, E90) 4 07-19-2004 09:44 AM
HELP! Turn Signal not working??? kraze0g 3-Series (E36) 7 06-22-2004 12:39 PM
