So I was in the trunk trying to figure out why the trunk light has never worked. All the fuses WERE fine...but then I found some wires in the trunk that had been cut, and sure enough they were the trunk light wires.
I connect the wires to each other and the first thing I notice is the the light still doesn't work. Then I turn the car on to see if that has something to do with it, but then I notice that the radio and OBC no longer work either.
The #21 fuse is blown so that explains why the radio and OBC don't work....
My question is, why would connecting the trunk light blow the fuse?
Should I have unhooked the battery before I spliced the wires?
I have since unhooked the trunk light to prevent another blown fuse....should I try hooking it back up now??
thanks!
thanks!
