bahahaha
oh well at least theres a positive outcome
just be sure to use an E36 trans or you will have a hell of a time fabbing up a trans brace...oh and dont forget the treehouse racing eyeball arm mounts to clear the exhaust manifold, you can run an entire E36 exhaust also with near zero modification...you have to indent the pipe over the sway bar so it will clear and other than that it fits
no joke alex is running the IE E36 cat back, and it fits almost perfect with the M50 in there...
