Trans. Problem - BMW Forum - BimmerWerkz.com
Old 11-01-2004, 03:48 PM   #1 (permalink)
bavariankid06's Avatar
bavariankid06 is an unknown quantity at this point
Send a message via AIM to bavariankid06 Send a message via MSN to bavariankid06
it might be b/c my car is 16 yrs old, but what's wrong if it's really hard to get in and out of each gear? it's like i hav to literally pull the shifter out of each gear and push it into the next
<img src='http://img.photobucket.com/albums/v305/crisby325i/Forum%20Sigs/BMWFSig.jpg' border='0' alt='user posted image' />
Mods:
Ireland Engineering Stage 3 springs
Bilstien Shocks/Struts
MB Motoring Rev 16x7 w/ Fuzion ZRi 205/45/16 tires
&lt;&gt;&lt;&gt;&lt;&gt;&lt;&gt;&lt;&gt;&lt;&gt;&l t;&gt;&lt;&gt;&lt;&gt;&lt;&gt;&lt;&gt;
<span style='font-size:8pt;line-height:100%'><span style='color:blue'><span style='font-family:Times'>Member of the 100,000 Miles Club</span>
<span style='colorurple'><span style='font-family:Times'>Member of the 3 Pedal Club</span></span>
<span style='color:red'><span style='font-family:Times'>Member of the &quot;I'm 17 and Own a Bimmer&quot; Club</span></span></span>
<span style='color:gray'><span style='font-family:Times'>Member of the 15 Yr Old Club</span></span></span>
Links:
<a href='http://www.cardomain.com/id/tigerzrule06' target='_blank'>On Cardomain's Top 5 E30 List!!</a>
<a href='http://www.photobucket.com/albums/v305/crisby325i' target='_blank'>.:My Photo Album:.</a>
<span style='color:red'><a href='http://www.seboc.com/' target='_blank'>S.E.B.O.C. - Southeastern BMW Owners' Club</a></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.petitiononline.com/STOPCB/petition.html' target='_blank'>11564th signer of the &quot;Stop Chris Bangle Petition&quot;</a></span>
bavariankid06 is offline   Reply With Quote
Old 11-01-2004, 04:46 PM   #2 (permalink)
alfamitch is an unknown quantity at this point
Synchromesh. Eventually you will not be able to access some gears at all. If you are planning on racing the car and making some serious power, then its time to rebuild. If you just do some light spirited runs, drive the car lightly and not planning to mod, then just swap in used trans, thats what I did.
alfamitch is offline   Reply With Quote
Old 11-03-2004, 10:21 AM   #3 (permalink)
If this applies to all gears it more likely to be the clutch not the gearbox sounds to me like somthing keeping the first motion shatf spinning so to sycros can't slow the gears enought check the hydrulics first clutch slave cylinders are common on E30s check the level of fluid if its down find the leak . If all thats OK remove the gearbox and check the clutch not just for waer but make sure everything slides freely ie friction plate on shaft and release bearing on its tube. If you need any info on removing the box or changing the hydraulics let me know.
93 325 Auto Trans Problem iXer_16323 3-Series (E36) 2 04-05-2005 11:25 AM
1994 325i Auto Trans Problem loftygoals 3-Series (E36) 0 01-12-2005 11:08 AM
Problem With My E34's Trans Cooler negowda 5-Series (E12,E28, E34, E39, E60) 0 10-16-2004 03:22 PM
2nd Gear Trans. Problem? bondmanz8 3-Series (E36) 1 09-10-2004 10:00 PM
Trans Problem on my 93 740i 7401bimmer 1,6,7,8 - Series and Mini Cooper 0 06-07-2004 11:17 AM
