TP switch/sensor input values? - BMW Forum - BimmerWerkz.com
Old 12-14-2008, 01:17 PM   #1 (permalink)
jeffie8696 is on a distinguished road
So does anyone know what the values coming from the Brown/Blue and Brown/Black wires coming from the computer should be? I know the solid Brown is ground.
jeffie8696 is offline   Reply With Quote
Old 12-14-2008, 02:38 PM   #2 (permalink)
I think I found it. Looks like 5 volts at the outer terminals and the center is ground. Let you know how it turns out.
Old 12-14-2008, 02:46 PM   #3 (permalink)
Thanks for keeping us posted!
Old 12-24-2008, 04:08 PM   #4 (permalink)
I have checked the values and found the following. The outside terminals each read battery voltage while the center reads 22 ohms. Ordinarily I would just run an auxilliary ground when I find a high resistance like this but the high voltage at the end terminals has me wondering if there is an error in the diagram? I know if the wrong wire from the computer is grounded it can ruin the ECU. Any suggestions? I am considering checking the wire at the ECU connector to check the continuity but it is just way too cold out there.
Custom made switch and lock/ unlock switch mod AlpineSixAndSeven 1,6,7,8 - Series and Mini Cooper 10 01-09-2008 08:22 PM
524TD Manual or Torque values DieselBeamer 5-Series (E12,E28, E34, E39, E60) 1 02-26-2006 02:05 PM
Hesitiation.mass Airflow Sensor Or Cam Pos Sensor? scopefrfd 5-Series (E12,E28, E34, E39, E60) 7 04-24-2005 11:47 AM
New Owner Values Your Opinions zzzzzer 3-Series (E46, E90) 2 03-28-2005 06:22 PM
Upgraded Sensor To Reduce Motion Sensor rsn48 5-Series (E12,E28, E34, E39, E60) 4 10-06-2004 02:44 PM
