Here, I found this:
Engine:
Engine total displacement: 2759cc's
Dyno sheet (4/30/05)
All new valve guides/seals
All new valves
All new rockers
3 Angle valve grind
JE 85mm Forged pistons 10.2:1 CR
TotalSeal piston rings
Lightweight wrist pins
81mm stroke crankshaft
Blueprinted & balanced bottom end
274/274 11.5mm lift Shrick camshaft
Heavily ported & polished head
Reshaped and highly polished combustion chambers
19lb Bosch Design II injectors
UniChip engine management
M52 HFM (MAF) conversion
Port matched intake manifold
Powder coated intake manifold
Powder coated valve cover
Custom CAI & heat shield
8mm red silicone ignition wires
173 DME Unit
I didn't do this one and from what I can tell there were many things I woudn't have done and some that were left out that I would have.
