Tire Wobbles - BMW Forum - BimmerWerkz.com
Old 02-20-2005, 09:22 AM   #1 (permalink)
Old_School_Bimmer's Avatar
Old_School_Bimmer is an unknown quantity at this point
Send a message via MSN to Old_School_Bimmer
My friend was following me in his car and he said that he noticed my rear driver side wheele wobbles any ideas on why it might be and is it hard to fix on my driveway? and how much would the cost be to repair it?
Theo
Old_School_Bimmer is offline   Reply With Quote
Old 02-20-2005, 12:15 PM   #2 (permalink)
Kowalski's Avatar
Theo
[snapback]295299[/snapback]
are your lugs tight? or is your axle straight?
264* roatation and 388 lift
Old 02-20-2005, 03:35 PM   #3 (permalink)
sounds like you have a bent rear A-arm
Old 02-20-2005, 11:14 PM   #4 (permalink)
Abdul is an unknown quantity at this point
Try swapping the rear tires from side to side and see if it is wheel related, or suspension related.
Abdul is offline   Reply With Quote
Old 02-20-2005, 11:42 PM   #5 (permalink)
Kowalski's Avatar
[snapback]295819[/snapback]
have your curbed that car recently?
Old 02-21-2005, 01:58 PM   #6 (permalink)
Never hit any curbs just squirrls they are dumb and un towards my car nothing i can do i always try to avoid them but better them then me or my car
Old 02-22-2005, 02:00 AM   #7 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
same thing on my car its the rear bearing is gone or going does it grind any????
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 12-08-2005, 10:21 PM   #8 (permalink)
TCossuto is on a distinguished road
bump- same except mine is undriveable- any suggestions?
TCossuto is offline   Reply With Quote
Old 12-09-2005, 12:26 AM   #9 (permalink)
and0pand0 is on a distinguished road
Hrmm.
Any noise coming from the hub? Could be a bad wheel bearing or CV joint, if so...
Check the CV boot and see if it's torn. If it is, feel inside the tear and if it feels grainy, like metal or dirt particles are inside, then it's toast and the axle needs to be replaced. If it feels like it's full of grease but not dirty, then the joint is still ok but the boot needs to be replaced (and this wouldn't cause a wobbling wheel). A new axle with ABS is like 130$ and w/o ABS is 120$. In a shop it would most likely be 1-2 hours diagnosis/labor so you may be looking at 250$-370$.
If it's a bad wheel bearing then it needs to be pulled out and replaced (non serviceable/need pullers) and I belive the bearing is somewhere of the neighborhood of 60$? This would cause a wobbling wheel. In a shop, it'll prolly be an hour or two diagnosis/labor, which means 180-300$.
If there's no noise, could be a bent hub, wheel or arm...
and0pand0 is offline   Reply With Quote
Old 12-09-2005, 02:01 AM   #10 (permalink)
Kowalski's Avatar
i just bought 2 rear wheel bearings for 30$ each.
325i Tire Question Ii fobbie 3-Series (E46, E90) 0 03-26-2005 08:09 PM
Tire Pressure Monitors chuckie789 1,6,7,8 - Series and Mini Cooper 2 01-12-2005 09:16 AM
Tire Question dtinsman75 3-Series (E46, E90) 1 01-10-2005 12:53 PM
