Good evening to everyone. I want to change the timming belt, tensioner, and water pump for good measure and havn't had the pleasure of performing this task as of yet. Any of you that have taken on this job yourselves, could you tell me about how long the job "should" take? I do have some mechanical skills, just have never changed a timing belt before. Any hidden suprises that I should lookout for? Any advise, helpfull hints etc would be greatly appreciated. Also, what else I might want to tackel while I'm in this area of the vehicle. Thank you in advance for your helpfulness.
Cheers,
Docho
Never did a timing belt on a BMW, but this link will help you. It rates it a 6 on the difficulty Level:
Thanks Torque, I downloaded the manual. This will be of great value when performing this task. Have you did a timing belt before? If so, what would you say would be a good time estamite to complete the job?
Docho
Me and my dad did one on my old 525i once, and honestly I don't remember any particular difficulties with it. But then again my dad works on cars for a living, so that plays a large part in it.
Shouldn't take more than 4 hours even for your first time doing it.
Budget a weekend of time. If you get done early, count it as a bonus. With my son's vert, changing the water pump was the worst of it, as getting the fan clutch off was a certified pain in the rear (and I had the right tools). On another timing belt change (not mine), the snag was with the vibration damper behind the bottom pulley not dislodging after the six pulley bolts were removed.
If the distributor cap/rotor and accessory belts need changing, this would be a great time to take care of those tasks as well.
Taking off the hood, removing the splash guard, and removing the radiator will give you more room to maneuver. Cleaning the water pump mounting area of old gasket material and using gasket adhesive with the new water pump gasket will improve your odds against a do-over because of a leak. Finally, buy a torque wrench if you don't have one in your tool kit.
Adios for now,
RM
__________________ On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Hey I've rebuilt the head twice and replaced the motor once in my 84 323i, it is an easy job to do about 1-2 hours if you've done it before. just make sure you follow what it says in the bently manual, oh ya to make it a hell of a lot easier you might want to take the hood off so the front of the motor is directly in front of you, and make sure you put the engine at TDC before removing the old belt. good luck
