tie end rods - BMW Forum - BimmerWerkz.com
Old 03-21-2009, 08:10 PM   #1 (permalink)
Car: 85 325e 90 525I '96 328i
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
tie end rods
1985 325e
should tie end rods move in a circular motion while attached or is that a sign of wear?
in wide turn radius you can hear alot of crap going on in the suspension, and the steering feels lose, especially in turns at high speeds. stabilizer links were replaced month ago, so i wonder if the problem is now the tie rod ends?
this leads to another question when replacing the tie end rods and bushings
how do you know if you need to replace the steering assembly or what not?
pinnaclebass is offline   Reply With Quote
Old 03-21-2009, 08:35 PM   #2 (permalink)
your gonna have to replace the control arms and bushings. Figure $400 if you have it done.....
silversled is offline   Reply With Quote
Old 03-21-2009, 08:50 PM   #3 (permalink)
my guess is not tie rod ends, it's more like ball-joints, these cannot be replaced individually, they require a complete new control arm along with the associated bushings..you might want to consider just doing the whole front end at this point....struts, pads, tires, alignment and so forth. I had these things done on a 1988 325iC in 2004, cost around $550. That was 25K miles ago (car now has 175K) and the thing is tighter than a drum. Good Luck
Tie rods mech9T8 3-Series (E36) 5 11-07-2005 11:48 AM
Tie rods mech9T8 3-Series (E36) 8 10-30-2005 07:21 PM
Tie Rods Cruzin 323is 3-Series (E36) 7 01-30-2005 09:15 AM
what should i get top end or low end power?? leobmw 3-Series (E36) 3 06-25-2004 08:56 AM
Replacing the Tie Rods Bmw1990 3-Series (E21, E30) 0 05-03-2004 09:00 AM
