Temperature Gauge - BMW Forum - BimmerWerkz.com
Old 06-05-2007, 08:28 AM   #1 (permalink)
jfertita's Avatar
Car: 86 BMW 325
jfertita is on a distinguished road
Temperature Gauge
Hey guys recently my engine temp gauge inside my car has been flickering from cold to hot and recently it has gotten worse and doesn't give an accurate reading at all. Is this because of the sending unit on the engine? Or could it be the batteries on the SI board? Also, the gas gauge does not give an accurate reading but it doesnt flicker like the temp gauge..
jfertita is offline   Reply With Quote
Old 06-06-2007, 12:04 AM   #2 (permalink)
Car: Opening soon:
Test by unplugging your temp sensor and shorting it to ground and watch the gauge, it should jump to hot and stay there and not move. You'll find it just behind your ignition cap and before your #1 injector, there you'll find two sensors that look the same. The one closest to the injector is for your computer and has two terminals the one next to it has only one, this is the sensor for your gauge.
Also depending on your year, check the main engine cannon plug for corrosion.
If these tests fail, your SI board could be causing the problem.
Old 03-23-2008, 09:58 PM   #3 (permalink)
Jonesz0003's Avatar
Car: 1991 BMW IS, 5 speed
Jonesz0003 is on a distinguished road
Send a message via AIM to Jonesz0003 Send a message via MSN to Jonesz0003 Send a message via Yahoo to Jonesz0003
did you ever figure out what the problem was, because im having the same issues.
Jonesz0003 is offline   Reply With Quote
Old 04-05-2008, 06:03 PM   #4 (permalink)
norcal325 is on a distinguished road
i have a 1984 325 and my temp gauge does not work either. i just got the car and want to make sure its not running to hot. where is my sending unit to do the test mentioned above? i followed the instructions above and there are like 4 plugs in that area, dont wanna ground the wrong one. thanks guys!!
norcal325 is offline   Reply With Quote
Temperature Problems e36surge 3-Series (E36) 12 12-14-2005 03:13 PM
Temperature Gauge Fluctuation Barriesza 3-Series (E46, E90) 1 01-10-2005 12:56 PM
Temperature gauge/thermostat mystery LeicaBimmer 3-Series (E21, E30) 5 06-02-2004 05:20 PM
Temperature Problems blurghy 3-Series (E36) 4 01-13-2004 11:09 PM
Eng Temp Gauge Hallatauer 1,6,7,8 - Series and Mini Cooper 4 08-02-2003 08:45 AM
