My temp gauge needle wont go above 1/4 and sometime jumps slightly around, is this a common problem? Any way to remedy this, also is this why my heat sucks?
Billy
__________________ 1991 Toyota MR2 Turbo (270whp)
1987 BMW 325e (110whp)
could be a bad ground behind your dash. That would possily make the gauge not read properly.
But if your heat does not work then most likely your thermostat is stuck open and your engine is not heating up. Do you get poor fuel economy or does your car run poorly?
Originally posted by RealBMW 02@Apr 19 2005, 08:17 PM could be a bad ground behind your dash. That would possily make the gauge not read properly.
[snapback]335080[/snapback]
well its not the greatest, but it does have 222,000 miles so I guess I cant complain. haha.
Billy
i had this problem. Check your water pump to make sure its still good. Mine was starting to go out so the thermostat would always be open and my temp would never reach normal temp. Finally the pump went out, I replaced it and it works perfectly now, just a little under normal running temperature
Originally posted by Numark318i@Apr 19 2005, 08:55 PM i had this problem. Check your water pump to make sure its still good. Mine was starting to go out so the thermostat would always be open and my temp would never reach normal temp. Finally the pump went out, I replaced it and it works perfectly now, just a little under normal running temperature
[snapback]335191[/snapback]
check your coolent level, thermostat either stuck open or closed, at 1/4 opp temp the heat should work because thats as hot as mine gets and iv got scorching heat. also check belts, and water pump. and verry unlikley but your heater core could be clogged.
__________________ M42 Custom ground cams for sale PM me
264* roatation and 388 lift
Originally posted by Kowalski+Apr 19 2005, 11:34 PM--><div class='quotetop'>QUOTE(Kowalski @ Apr 19 2005, 11:34 PM)</div><div class='quotemain'><!--QuoteBegin-Numark318i@Apr 19 2005, 08:55 PM i had this problem. Check your water pump to make sure its still good. Mine was starting to go out so the thermostat would always be open and my temp would never reach normal temp. Finally the pump went out, I replaced it and it works perfectly now, just a little under normal running temperature
[snapback]335219[/snapback]
[/b][/quote]
Ok cool Ill replace the T-stat and see if that fixes it. Any chance its the coolant temp sensor or are they pretty reliable?
Billy
It should be your T-stat. I had the same problem. I bought my car from down south and it was equipped with a T-stat that made the engine run cooler. I replaced it and now it works fine.
I would start just by checking the connection on the sending unit for temp gauge, they tend to get corroded (spellcheck..) and not function properly, check coolant level of course, and go from there... Good luck
