Techometer, Gas, Coolant gauge - BMW Forum - BimmerWerkz.com
Old 04-29-2004, 10:58 PM   #1 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
Okay, Tach, gas, and Coolant guage stopped working in my 89 325iS, any clues? my mech said that it was the service board or something, but those are like 179$ at bavauto. And I dont really wanna pay that. My speedo still works which is good, but according to that 'fuse 21' thread, all schnieder did was put in a new fuse. does anyone know which fuse I woul dhave to replace? or what I would have to do to get my ish working again?
thanks,
dan
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 04-30-2004, 05:55 AM   #2 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
Fuse, uh, 21.
I guess they're numbered somehow.
It's the cure-all for E30 cluster malfunctions.
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 04-30-2004, 12:02 PM   #3 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
If you cannot read the numbers on your fuse box cover a simple multi meter and a few minutes will identify which fuse is bad. Does the fuse blow when you put the car into reverse, 1st, 3rd or 5th? The wires from the reverse light switch in the tranny run through the same hole as the shifter and in some cases with a worn shifter and linkage enough play is in the mechanism that it will short the wire causeing selected guages to go out. Apparently the reverse light swith and some guages are on the same circuit. It took me about 2 weeks and 20 fuses to realize what was causing my guages to die.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 04-30-2004, 04:08 PM   #4 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
so just get some new fuses? I dont need any certain kind, just some fuses?
Old 04-30-2004, 05:38 PM   #5 (permalink)
schneider252's Avatar
its eather 21 or 10 and there both 10amps...it shoudl be labled reallly small geta flash light or sumthin....if its no there i can go and take a look at tell u how many over it is
Old 04-30-2004, 06:25 PM   #6 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
MUAHAHHHAHAHA, FIXED IT! WOOT, so much cooler, Ive been running with no tach for like 2 months now, I can handle it, but its just nice to see where the RPM's are at in the canyons.
Though I know where the RPM's are at certain MPH, its still nice to be re-assured.
Old 04-30-2004, 11:53 PM   #7 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
the fuses that are for OBC are 10, 12, 21,27 and 30 i think
Fox is offline   Reply With Quote
Coolant Temp Gauge Just Stopped! 325eXTATIC 3-Series (E21, E30) 1 07-28-2005 12:01 AM
Leaking Coolant uclabruins1996 3-Series (E36) 13 10-30-2004 09:01 PM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
E39 coolant level sensor NC540i 5-Series (E12,E28, E34, E39, E60) 4 05-27-2004 12:56 PM
Coolant Question charles01 3-Series (E21, E30) 1 03-06-2004 06:57 PM
