Tail Light Issue - BMW Forum - BimmerWerkz.com
Old 12-18-2007, 08:29 PM   #1 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
Tail Light Issue
So after I did the bumper swap on my 88iS, I had to use small bumper turn signals(obviously), but they use a different female plug then the 88's.
So, I broke apart the original male plug of my car's turn signals(cleanly), and plugged them in correctly..The turn signals worked! BUT!! My driver side turn signal would not go into "Running" mode.
Also, now my Driver Side Tail Light does not work. All the fuses are good, and I replaced the Tail Light Bulb..but it still wont turn on and I get the indicator on my panel next to the rear view mirror.
Any suggestions before I turn it into a Mech Shop?
Maybe play with the wires that I plugged into the turn signal? That is the only thing I can think of..so I'll mess with it.
Also, I tried using my friends Light Plate(the thing that holds all the tail light bulbs) on my car, and the tail light is still out(all the other lights work, just not the RUnning Light).
Anyone?
-Dan
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 12-18-2007, 09:41 PM   #2 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
Did you switch the bulbs to either side?
My BMW Blog
Old 12-19-2007, 02:00 AM   #3 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
yup, tried so many different combos...new bulbs i purchased match the old ones perfectly. driver side front and rear running lights just wont go on.
Old 12-19-2007, 03:19 AM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
.... sounds like a fuse...... not sure though......DB check them....
1992 318i Coupe parts car
I am Captain Obvious
Old 12-19-2007, 09:25 AM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
weird, if anything is sounds like the wires are backwards or something but i didnt have any issues with my swap, did you get both pieces of the late connectors? male and female? or did you just twist some wires together? lol
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 12-19-2007, 04:01 PM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I'm not sure why you are having a problem with the side markers. The side markers that fit the plastic bumpers also fit the late almn. bumpers so you should not of had to swap anything. For the tail light check the pins in the bulb carrier where it plugs into the tail light. You can remove the connector with the pins in it from the tail light, its just held in with plastic clips. Make sure all the contacts are clean. Also make sure you have the right wattage and type of bulb in the carriers.
My M50 Powered E30 Page
Old 12-19-2007, 04:43 PM   #7 (permalink)
gotKRAUT's Avatar
ohh good call i was thinking he meant turn signals...the side markers are the same, he is correct
Kyle Sutherland
1995 BMW 540i/6:
Old 12-19-2007, 09:41 PM   #8 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
The rear side marker works just fine, but the front one doesn't, I haven't replaced it yet though. I will do that soon.
I did not buy both pieces for the turn signals, I actually broke apart the original male plug, and took the wires out(pre-crimped actually), and they sort of slid right over the 3 pins in the turn signal housing. But I will go purchase the small-bumper male housing tomorrow.
Thanks..I'll keep you updated.
Old 12-20-2007, 09:27 AM   #9 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Ohhhhhhhhhhhhhhhhhh, I get your problem now. I just didn't read your post right the first time, I kept thinking you were only having an issue with the side markers. Easiest fix is to just go to the junk yard and cut off the pig-tail for the front turn signal from an 89+ car to use with the later style of turn signal. You might be able to make it work with what you are doing but it might take a while with trial and error.
Old 12-20-2007, 09:44 AM   #10 (permalink)
gotKRAUT's Avatar
ya alex and i did mine in a matter of minutes
Kyle Sutherland
1995 BMW 540i/6:
Old 12-20-2007, 10:51 AM   #11 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
Alright I think I got it, but I will trial and error when I go home for xmas next week.
Tail Light Help! Bimrboy 3-Series (E36) 5 08-06-2005 11:57 PM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
TAIL LIGHT FALIURE 007ben 3-Series (E36) 5 04-10-2004 10:27 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
