Tachometer Not Functioning - BMW Forum - BimmerWerkz.com
Old 12-04-2004, 02:30 PM   #1 (permalink)
plusnone's Avatar
plusnone is an unknown quantity at this point
Send a message via AIM to plusnone
Hey everyone-
I have a slight problem with my '87 325. The tachometer doesn't work. I've searched this forum and others for info, and have read that it might be a fuse. However, the fuse that is mentioned also connects to the temperature guage and the clock, both of which work. All of my other guages work, could it still be a worn-out battery in the instrument panel? Or is the more likely culprit simply a bad connection?
The tach has worked once: my car sat for a week or so while I gathered funds for and then installed a new starter, then when I started it up, the tach worked. However, the next time I started my car, it didn't work. Also, when I turn my car off, the tach quickly flicks from zero to ~1000 rpm and then back to 0; there seems to be some sort of connection.
What would be the best place to check? I suppose I'll have to check behind the instrument panel, but because that involves taking off the steering wheel, I'd like to know if there's somewhere else I should check first. (it's not that big of a deal, I'd just like to check the simpler places first.)
Thanks,
-plusnone
My 1987 325 is no longer. Rain and an relatively inexperienced driver are not a good combination, to say the least. Luckily no one was seriously injured.
plusnone is offline   Reply With Quote
Old 12-04-2004, 02:51 PM   #2 (permalink)
87 325iS is an unknown quantity at this point
FYI, you don't need to take the steering wheel off to get the instrument cluster out.
Amberfire 2000 Dodge Dakota R/T
Rusted, fallling apart Alpine White 1987 325iS - Gone but not forgotten
<img src='http://img.photobucket.com/albums/v255/HeilSova/Sig.jpg' border='0' alt='user posted image' />
87 325iS is offline   Reply With Quote
Old 12-05-2004, 04:55 AM   #3 (permalink)
steeN's Avatar
steeN is an unknown quantity at this point
Send a message via ICQ to steeN
You need Haynes manual or so i think. Everything there is described step by step...
Probably your right dash connector is bad(the dash has two connectors at the back, the left is mainly for the left part of the dash and the right is for .. the right ) Your tach circuit board may have gone bad too. Just take the dash off, take it apart and search for bad joints and loose connections. This works fine most of the time.
confirmed.
Hope this is helpful
<span style='font-size:11pt;line-height:100%'>
It seems they wanna finger print me and gimmie some years
They'll only get 1 finger while I'm shifting gears
</span>
<span style='font-size:8pt;line-height:100%'>
Drag racing an m3 is like going fishing with a hooker, it's fun but it's not what you got her for.
There's no replacement for displacement.
I need to know!
</span>
<img src='http://steen.hit.bg/i_hate_riceers.png' border='0' alt='user posted image' />
steeN is offline   Reply With Quote
Old 12-05-2004, 03:15 PM   #4 (permalink)
plusnone's Avatar
Oh, great, that makes it quite a bit easier. I don't really want to take the wheel off because I don't know how hard it is to align it correctly afterwards. But now this is a bit of a simpler task.
I have the Bentley manual, and in the instructions to remove the instrument panel it says to remove the steering wheel as well.
I'll play with it a bit and see what happens, then. Thanks for your help.
-plusnone
Old 12-05-2004, 04:09 PM   #5 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
-plusnone
[snapback]244012[/snapback]
to keep alignment of the wheel.
before you remove it, take a felt pen, magic marker or even a knife
and
mark a slice from the outer housing to the center spindle.
easy, if you ever have/want to remove the wheel
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Old 12-05-2004, 04:14 PM   #6 (permalink)
plusnone's Avatar
Ah, that's a good idea. Thanks for that tip, I'm sure it'll come in handy soon.
-plusnone
Old 12-06-2004, 08:34 PM   #7 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
tech not working is most likely a fuse.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 12-06-2004, 10:09 PM   #8 (permalink)
idanity's Avatar
[snapback]244843[/snapback]
i agree to a fuse ONLY on one thing thats clear its not a fuse
in the first thread it states th etach does work for a second or two, up to 1000 rpm then off.
by deduction it cannot be a fuse, ( i do agree to replace them anyways) and if so.
would also mean that something "BLEW" THE FUSE in the 1st place.
trace your footsteps back to the work you did on the starter and with a high powered flashlight search for a broken wire or maybe you crimped the wire somewheres under the car ,
maybe the wire is too close to the exhaust or anything,.
the relative chance that you caused this is very high.
due to the fact of the problem starting right after the repair.
good luck and take some pics.
Old 12-06-2004, 10:52 PM   #9 (permalink)
plusnone's Avatar
[snapback]244926[/snapback]
I guess I was a bit vague in my first post. I purchased the car in September, and the tach didn't work then. The only time it has worked was for a short time (first ride, about 1/2 an hour) after I got a new starter installed (which I didn't do myself, unfortuately). I didn't get a chance to work on it last weekend, but hopefully this weekend I will. I'll let you know how it turns out.
Thanks
Broken odometer and tachometer 86 325 incremus 3-Series (E21, E30) 5 03-06-2011 04:50 PM
Fully functioning e32 sound system BUT JayKayNZ Audio and Electronics 2 09-14-2005 06:28 AM
Questions On Tachometer & Lcd caldoone 3-Series (E46, E90) 4 01-24-2005 06:18 PM
Tachometer Not Working, Help?? Aznhiga 3-Series (E21, E30) 6 11-02-2004 01:04 AM
Non functioning Engine check Light 1988 750iL JNordman 1,6,7,8 - Series and Mini Cooper 0 04-10-2004 04:25 PM
