Nice assortment of parts, looks like you got it well covered... I'll bet it goes together alot easier than it came apart . This is going to be my next project also. Just take your time and you should be just fine.
PS> Where did the sway bars come from??? THX & Happy Wrenching
this is what i did so far...
- installed frame brake lines,
- rear sway bar,
- trailing arms into sub-frame,
- 3 jacks, raise whole assambly, wiggle in and attach old shocks to trailing arms., then you can pullback and forth on subframe assambly, line i up with S/F screws, dont forget washer between bushing and frame.
Originally posted by fporro@Apr 14 2005, 04:34 AM rears are 4 lugs, redrilled from 5 hole rotors. keeping 4 hole set up.
fronts are 2 piece type. the brakes are an early version of IE's Big Brake Kit.
- rear sway bar,
[snapback]332152[/snapback]
Wowsa! Great setup, what'd all the parts run you? $$$ My car needs susp. upgrade BADLY, dont have the cash now but I think I am going to start with the sprins (so it'll look better to start..) I have recent struts in the front ( about 8 months old) They are BOGE, they are ok, not great, they tend to let the front end of the car come up a little high if you hit a good bump, recovers quick, dunno if springs are going to help/hurt... Either way, nice setup man!
ok, i am going to be your "mom" here......but i have seen/heard way too may people hurt themselves while working on cars.........
run down to sears and pick youself up a good pair of jack stands......hell pepboys or the like carry fairly decent ones as well......they are super cheap, like 30 bones or so..........i like all the mods and the work, just want to make sure to have you around for many miles
__________________ sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
thanks man,it took me a little while to gather everything, uhm, it set me back about $ 3,500 bucks.
an economical way to drop the car is by swaping spring pads for thinner ones, +/- 1/2 drop.
you're the 3rd os so person that mentions jack stands, i'm working on the safe side, they're put of camera range. thansk never the less.
It's been a slow 2 days, Tax time.
Anyways, replaced the passanger side parking b. cable and painted the brake rotors and calipers. It seems that i'll need to reinstall rear brake back plates so i can attach parking brakes shoes to it. hahaha, PASS THE HAMMER !!!
Will the H&R springs lower the car to the point where your going to need ajustable camber kits in the rear trailing arms ??? I need to do something about the negative rear tire camber on my 87 325ic. Not sure if I should go with eccentric poly's or go with the weld-ins. What was your choice in this matter ? THX
