surging under steady throttle - BMW Forum - BimmerWerkz.com
Old 06-15-2004, 09:25 PM   #1 (permalink)
rknail is an unknown quantity at this point
What could cause an 86 BMW 325ES to suge when the throttle is held steady?
In other words i don't move my foot on the gas pedal but the car surges up and down in RPM.
Any help would be appreciated!!
rknail is offline   Reply With Quote
Old 06-15-2004, 11:10 PM   #2 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
I get a little bit of that. It could be something with the throttle cable, or more likely just dirty injectors or some other clogged part of the fuel delivery. Your oxygen sensor could be cracked as well, but in that case you'd have a few other additional problems that you didn't mention.
Welcome aboard!
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 06-16-2004, 12:47 PM   #3 (permalink)
kirbanana's Avatar
kirbanana is an unknown quantity at this point
sounds like a vacuum leak somewhere....check your hoses and boots...
kirbanana is offline   Reply With Quote
Old 06-19-2004, 11:48 PM   #4 (permalink)
Car: Opening soon:
For starters, clean the throtle body valve. Then clean the idle air motor it could be sticking. Then check your air meter, the box that houses your air filter (mass air flow sensor some call it) move the valve in there slowly by hand and see if you feel any resistance or binding.
Good luck
Whistle when throttle at certain positions Satori325XI 3-Series (E46, E90) 23 08-09-2008 01:51 PM
328i Lazy Throttle Response johnnybad1 3-Series (E36) 4 09-26-2005 11:39 AM
Let's Talk Throttle Body's jllphan 3-Series (E36) 2 01-31-2005 09:41 PM
Boring Out Throttle Body and Heads WickedBimmer 3-Series (E36) 9 03-27-2004 10:26 AM
525i - Engine surging - high RPM ron 5-Series (E12,E28, E34, E39, E60) 1 03-04-2004 07:14 PM
