stupid odometer - BMW Forum - BimmerWerkz.com
Old 07-09-2006, 10:58 AM   #1 (permalink)
325iXer is on a distinguished road
stupid odometer
everything has been great on my 1990 325iX. Its been running great. And now, out of the blue, the odometer stopped working. no trip odometer either. any thoughts? where do i start. any help is appreciated. thanks
325iXer is offline   Reply With Quote
Old 07-09-2006, 11:47 AM   #2 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
You're gonna have to get a new car...
Just kidding.
You can start by checking the connectors on the back of the cluster. Also you can check the speed sensor on the back of your differential to make sure its still alive.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 07-10-2006, 08:20 PM   #3 (permalink)
Car: 86 325es
smokinE_30 is on a distinguished road
Are you saying that the mph and odo each have a connection on the diff. so one can come loose and not affect the other?
My ODO does not work either, all other gauges work fine.
smokinE_30 is offline   Reply With Quote
Old 08-27-2006, 07:31 PM   #4 (permalink)
95bmw540i is an unknown quantity at this point
99% its the plastic gears within the unit itself. take out the cluster, unscrew the back to get to the odometer, the gears are plastic and break over time,
95bmw540i is offline   Reply With Quote
Old 08-27-2006, 08:50 PM   #5 (permalink)
Car: Opening soon:
Actually, it's more like 99.9% of the time. The grease they put on the rubber like gears dissolves them over time.
Old 01-11-2007, 01:34 PM   #6 (permalink)
Redhaze737 is an unknown quantity at this point
Removing and Replacing
I've removed the odometer and ordered the new gears. The question is - how to remove and replace the gears without damaging the odometer. Do the gears just slide off and on? Is there an index on the shaft that the gear has to match? The smallest gear has what looks like a brass center. Does that gear just pull off? Any guidance will be great.
I really appreciate you experts helping us poor souls out. Paying BMW megabucks to replace the entire unit is just unacceptable. :=)
Redhaze737 is offline   Reply With Quote
Old 01-11-2007, 08:04 PM   #7 (permalink)
Car: Opening soon:
The brass pice needs to be pressed off (pain in the a$$) or if you are careful enough, use a dremel and buzz it off (works great, just don't slip) I don't know of you have the direct replacements, or the plastic push on ones (if you can get them any more)
I have rebuilt several so being that this is your first time, buy a spare and practice taking it apart and take your time, because the clear plastic doesn't take very well to force. If you want one let me know I have a few bad ones you can practice on.
Old 01-12-2007, 12:18 PM   #8 (permalink)
Thanks for the info. I purchased the gears from Odometer Gear Replacement
I read somewhere else that you can 'cut' off the small gear with the brass insert using a pair of side cutters. I'll approach it with caution. I may contact you for a practice piece. Thanks for the offer.
Old 01-21-2007, 02:08 PM   #9 (permalink)
Success! I used a pair of side cutters to get the brass insert off. It's brittle so when you clamp down it just splits off. Put all the gears back together and it works fine.
I'm German so I should understand but it seems like that's a lot of gearing to turn one shaft. used: That seems more English to me.
Old 02-02-2007, 12:06 AM   #10 (permalink)
What number gears to get?
Red I gotta do the same thing to my project car ('90 325i). What number gears did you get? There's a couple of different sets to choose from. Thanks.
-Mike
Hamfisted is offline   Reply With Quote
