Strong Gas Odor - BMW Forum - BimmerWerkz.com
Old 03-11-2005, 12:42 PM   #1 (permalink)
SteveO325is is an unknown quantity at this point
every time I get out of my car I smell this strong gas smell, there are no visible leaks and I don't see any fuel around the lines/filter... any ideas as what it could be? I do hear a noise that could possibly be fuel though, it makes a sweeeeesh noise :lol: Not sure if that's normal or not on these cars
SteveO325is is offline   Reply With Quote
Old 03-11-2005, 10:57 PM   #2 (permalink)
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
This is most likely caused by a charcoal filter right at the tip of your gas tank where u fill your tank at. Teh filter becomes defective because if you fill your gas tank all they way to the brim, the filter becoems saturated, and becomes ineffective. I am pretty sure this might be the problem.
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 03-12-2005, 06:58 AM   #3 (permalink)
it has a stronger smell on the driver side, almost around the fuel filter.. so as I'm driving, it's a very strong smell
Old 03-12-2005, 11:55 AM   #4 (permalink)
Bmw1990's Avatar
alrite check your fuel filter. But i would defintely check out what i was talking about.
Old 03-12-2005, 12:07 PM   #5 (permalink)
I get that sometimes, fuel pump relief was what I was told can cause that, but if it's a lot maybe the fuel system needs checking
Old 03-12-2005, 02:13 PM   #6 (permalink)
I had that odor from my married daughters 325ic and then fuel started leaking on my foot just aft of the drivers door and after shutdown. I put her in the air and found that one of the fuel lines from tank to filter had a minute hole. Bottom line, get her in the air and take a look.
Old 03-12-2005, 10:06 PM   #7 (permalink)
Kowalski's Avatar
charcole canister when it goes bad it reeks like gas, or if you over fill your tank (pull the trigger after auto stop happens) it can also wreck the charcole canister, they're pricy, so i just removed mine.
264* roatation and 388 lift
Old 03-12-2005, 10:42 PM   #8 (permalink)
[snapback]309610[/snapback]
Yup, now that I think about it, my fuel line right at the pump went bad and started leaking. It had to be replaced
Old 03-12-2005, 11:03 PM   #9 (permalink)
next time I'm at a shop I'll check it out... I haven't seen any gas on the ground, or even really bad gas milage... I'm not sure what's average for these cars, but I've been gettin about 25 or so city miles (opening it up occasionally)
Slow to start - gas smell irish 3-Series (E21, E30) 2 11-01-2005 02:42 PM
Erratic Gas Guage misterervin 3-Series (E21, E30) 5 09-22-2005 08:20 AM
