Stripped filler plug on differential - BMW Forum - BimmerWerkz.com
Old 07-20-2009, 11:13 PM   #1 (permalink)
bobome is on a distinguished road
Hi, anybody know how to take off a stripped filler plug on the differential? Please help. Thanks
89 325iC 5sp
90 325iC Auto
bobome is offline   Reply With Quote
Old 07-21-2009, 12:41 AM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
When that happened to me I had to pull off the dif cover and replace the entire cover.
And when I say "I" I mean my mechanic.
yammahamma is offline   Reply With Quote
Old 07-21-2009, 10:53 PM   #3 (permalink)
my question would be, why even change the differential fluid? shouldn't have to and it's a much bigger pain in the ass to do then it's worth...but yes, idiots typically round the 4 sided drain plug off so you can't get it out any longer. It's a classic problem...the old diff plug..what I have seen is that folks take the bottom plug out, via whatever means, drain the fluid and then discover that the filler plug won't come out, the one on top, so they can't refill the damn thing...either way you/they are screwed....I wouldn't even mess with the differential fluid...if the thing goes it goes....and you replace the entire diff.....best of luck
silversled is offline   Reply With Quote
Old 07-21-2009, 11:11 PM   #4 (permalink)
Read it on PelicanParts.com
Pelican Technical Article: BMW E30 3 Series Differential Oil Change
I done it before it was not hard at all if the filler plug was not stripped. Shifted much smoother after oil changed. Advice for the first timer changing the differential oil, ALWAYS take the filler plug off first then the drain plug. In my case, if I drained the oil first, then I'm really screwed.
89 325iC 5sp
90 325iC Auto
Old 07-22-2009, 09:44 PM   #5 (permalink)
actually I think it's an Allen isn't it on the BMW? I may thinking of Peugeot with 4 sided wrench thing, piece of junk Peugeots are...nevertheless....the situation remains the same, take the filler plug off first and then see if the drain plug will come out..that way you won't can't be stranded...good luck..cliff
Old 07-23-2009, 01:59 AM   #6 (permalink)
Sorry it was the transmission filler plug not the differential. Yes you will need to use a 17mm hex bit. If I can't get it off then I can't change the transmission oil, anybody got a solution to this problem?
89 325iC 5sp
90 325iC Auto
Old 07-23-2009, 02:23 AM   #7 (permalink)
yammahamma's Avatar
Car: '01 330i
weld a nut on the plug and crank that out, maybe?
Old 07-23-2009, 02:53 AM   #8 (permalink)
Ok thanks
89 325iC 5sp
90 325iC Auto
Old 07-23-2009, 11:02 AM   #9 (permalink)
yammahamma's Avatar
Car: '01 330i
^^^ I should say that I've never done that myself...but I've heard of it being done.
Old 07-23-2009, 11:21 AM   #10 (permalink)
romeomike's Avatar
Car: 91 318i, 90 325iC, 2004 325i
romeomike is on a distinguished road
Tools similar to this
Amazon.com: Alden 8440P 4-Piece Grabit Broken Bolt and Damaged Screw Extractors Set: Home Improvement Amazon.com: Alden 8440P 4-Piece Grabit Broken Bolt and Damaged Screw Extractors Set: Home Improvement
I don't know where you live, but if you Google search on removing broken bolts, you may find a professional in your area to help this along if you're uncomfortable doing it yourself.
romeomike is offline   Reply With Quote
Old 07-23-2009, 02:37 PM   #11 (permalink)
Thanks I live in San Francisco and I will search to see if anything available. I don't want to light up a torch underneath the car.
89 325iC 5sp
90 325iC Auto
Old 07-23-2009, 03:03 PM   #12 (permalink)
89 325iC 5sp
90 325iC Auto
Old 07-23-2009, 08:25 PM   #13 (permalink)
actually, you are screwed to begin with if you can't tell the difference between a differential and the transmission...what? I see no fruitfull outcome on this effort.....
Old 07-23-2009, 08:32 PM   #14 (permalink)
romeomike's Avatar
You could post in this forum, and see if you can get any recommendations there
California - BMW Forum - BimmerWerkz.com
Good luck with it.
Oil Plug Stripped! Now What ?? Funk 49 5-Series (E12,E28, E34, E39, E60) 10 10-07-2010 11:13 AM
Stripped Lug stud Eraj 3-Series (E46, E90) 0 10-02-2007 07:38 PM
stripped spark plug maybe a big prob seven 3-Series (E36) 8 06-18-2007 12:29 AM
I Fear My Differential Is Being Stripped To Death bitcore 3-Series (E36) 7 02-01-2005 10:02 PM
325i Being Being Stripped spacer325i Classifieds Sell & Buy 8 12-11-2004 06:44 PM
