Stress-boring? - BMW Forum - BimmerWerkz.com
Old 12-15-2006, 12:04 AM   #1 (permalink)
Car: 1984 BMW 318i
daklunk is on a distinguished road
Question Stress-boring?
I was reading a thread on e30 tech about preparations for turboing an M10 and it was suggested that the person should get lower compression pistons and have the block stress-bored. Now, I knew about the lower comp pistons, but "stress-boring" is new to me and a search on Google and it turned up something from a Skyline forum. From what I read, it has something to do with a procedure that prevents the block from deforming...
But what exactly is this procedure and what does it entail? Is it spendy? I'm thinking about a turbo M10... :
daklunk is offline   Reply With Quote
Old 12-15-2006, 07:01 PM   #2 (permalink)
Car: Opening soon:
Its called honing with a torque plate, the stress from fully torqued head bolts can distort the cyl bores. A torque plate is a mock cyl head that has large open holes where the pistons go, they torque down the torque plate to the head bolt specs. These holes allows the cyl bores to be honed while under torque stress. Then after this is complete and you install you head and torque it to specs it'll distort the cyl back to where it was honeing was done, bring it back to a near perfect radius. Allowing the piston rings to seat completely for the full stroke.
Being one that builds high performance motors and going to take my ASE master machinist tests soon, I highly recommend this procedure.
Old 12-15-2006, 09:06 PM   #3 (permalink)
Car: 1984 BMW 318i
Ah, OK. That makes perfect sense. Thank you, sir! I'm browsing through VAC Motorsports right now and they have an M10/S14 torque honing plates, and that makes me wounder, will I need to buy one of these before taking the block to the machine shop?
Is it all right if I ask you some questions via email, Starmavin? I'm going to look into this a bit more, but I know I'm still going to have a lot of questions...
Thank you very much!
Old 12-15-2006, 09:23 PM   #4 (permalink)
Car: Opening soon:
As far as having to buy one, you shouldn't have to buy one, any shop that has the know-how or experience should already have one or access to one.
I don't mind.
rear strut mounts and stress bars theironm0nk 3-Series (E36) 2 09-09-2005 01:02 AM
Stress Bar anthony303 3-Series (E46, E90) 12 04-03-2005 03:23 PM
TB Boring Kevin325i 3-Series (E36) 13 07-08-2004 01:50 PM
BMW says 'nein' to boring vehicles Stacy540i Bimmer Talk/Motorsports Talk 5 12-01-2003 08:19 AM
