ghead Well I have tried to figure out my tranny but still no cigar, just to fill you in once more... I replaced my engine (m20) from my 89 325i, I put in an engine from a 91 325is. To my content it started right up, BUT when I put it in drive it kinda jerked and then it would go no more. ... Please help me, I just bought the Chilton book but it doesnt have anything about that. If anyone has had a scenerio such as this or experienced somthing like it tell me please...once again I thank you in advance.
Consult an actuall mechanic. This sounds like one of those times when you should have had a pro do it.
Have you completely removed then re-installed the clutch?
__________________ <span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
Originally posted by flipsgonetopless@Dec 18 2003, 04:49 PM Well its an automatic...
Were both cars automatic? Sounds to me like the problem is in the linkage or something. Again, check with a mechanic. We can sit here all day and gues, but will probably end up being wrong.
Good luck
I'm an American Muscle car guy, but I own, and play with a couple of BMW's...
Maybe this will help.
If it were an American car, I would say the "lock up" function on the torque converter is malfunctioning, or is otherwise connected wrong.
On american cars, when they do this, the "lock up" is engaged, and when you drop it into gear, it's like "dumping the clutch" on a manual tranny car at idle.... But with the automatic, there's enough "cushion" in the auto tranny that the car wont jump forward....
Can you start/run the car when it's in neutral?
If you can, have someone push your car up to about 10 mph, then drop it into gear while it's rolling. If it runs and drives, but dies when you come to a stop, then you have found your problem. The solution is to then find where you have wrongly connected the wires.
Or it may be a vacuum leak that kills it when you put load on the engine [by putting it into gear] Lotts of Vac lines on BMW motors, check your routing.
That's about all I can think of right now... Good luck
Darryl Roederer
__________________ Darryl Roederer
Louisville Ky.
The "buick" guy
