Steering Wheel Installation / Horn Operation - BMW Forum - BimmerWerkz.com
Old 08-22-2007, 07:22 AM   #1 (permalink)
snpower is an unknown quantity at this point
I removed the steering wheel as part of my cruise control troubleshooting. I marked the wheel as noted in the Bentley manual to aid with re-installation. There is a small carbon pin that protrudes from the steering column; I assume this needs to fit inside the small opening on the rotating slip ring inside the wheel itself. It took some time to get everything to align. During my road test the horn kept going off when I turned the wheel.
Back in the garage, I removed the wheel momentarily, then reinstalled. This time I did not align the carbon pin with the slip ring and now the horn works only when I press down on it.
I don't understand the functionality of this carbon pin and slip ring assembly - is it part of the horn circuit? Pin alignment is not mentioned in the Bentley's manual as part of the wheel reinstall.
snpower is offline   Reply With Quote
Old 08-23-2007, 10:20 AM   #2 (permalink)
Pin
Do you mean the lock pin for the steering wheel that requires the ignition key to be turned to the on position to get the steering wheel fully seated onto the splined shaft?
Old 08-23-2007, 12:24 PM   #3 (permalink)
No, it is the carbon pin, part # 32 33 1 350 750 in THIS diagram:
http://bmwfans.info/original/E30/Cab...2/ill-32_0854/
97 740IL no horn or steering wheel controls?? BUugman 1,6,7,8 - Series and Mini Cooper 0 08-09-2006 01:08 PM
Would this VICTOR steering wheel fit an E36? (see pics) Delmarco 3-Series (E36) 0 01-01-2006 03:43 PM
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
