1990 320i auto. just started happening today.
car runs fine once it is started. If i am driving around and turn it off, leave it for 1 minute then come back and start it again it will start fine. But if i am driving around, turn it off and leave it for 5-10 minutes plus, when i try to start it the engine just turns over and doesnt fire even if you hold it down for like 5 seconds. after 3 or 4 attempts of this result it starts and then runs fine.
It doesnt make a difference if i try to start it in park or neutral. any ideas?
Hmmmm... sounds like fuel pressure as after say a 1min the pressure is still there but diminishes after being stood and you have to keep cranking it up until the pressure returns, could be your fuel pump..as there's a non- return valve and if this goes the fuel drains back to the tank.
i did a cold start after it had been sitting in the garage over night and it started fine i turned it off and tried a couple more times - no problems. Would this mean that it isnt loosing fuel pressure as it certainly would have lost it over night or would the different settings for "cold start mode" compensate the loss of fuel pressure
is that possible even though it runs fine once started and starts fine if i only leave it for 1 minute?
it happens. it would be a short inside the ignition coil winding if that be the case.
If you can get you hands on a known good coil, it's an easy switch to test.
fuel pressure like marti sez, very possible too. either the lack of pressure at start-up... or too much of it like flooding; and good indication is if u smell gas fumes when the hard start episode displays.
OR, pull out your plugs when u have those hard start periods. plug condition will tell you a lot black & dry; black & wet, brown, grey, white...
TIP: maybe time for a tune-up? esp. if you hv been using platinum plugs. ur bimmer series does not like platinum, or the bosch +2 or +4 plugs. Stay with good ole' copper core.
i use ngk zgr5a's thanks for the heads up about coil and fuel pressure its given me some things to think about
i bench tested my ignition coil although i am a little confused. The haynes service and repair manual says their are two type the tci system and later motronic system. My car is a facelift and has the motronic system (as it says motronic on the ecu) but my ignition coil says "TCI - ignition coil" ?
hi, just to give you an update ..
I changed the main relay and it didnt make a difference. I am now halfway through replacing the crank shaft sensor, the allen bolt holding it in place was to tight for my 3 inch long allen key so i am letting it sit in crc over night, hopefully the bolt will have loosened up by morning.. i have to be somewhere at 10am
well this is starting to be a real pain in the ass. I changed the crank sensor went for a test drive of about 10 - 15 minutes. Came home, started it up about half an hour later andit cranked for about 7 seconds then fired and ran like crap at idle for a second or two and then died. Started it up again and then it was ok..
things i havnt checked
fuel pressure (remember the car cold starts fine)
Fuel filter, it looks old but this problem just started happening all of a sudden which makes me think it would be electrical and a dirty fuel filter would make it slowly harder to start over time wouldnt it.
