SRS frustration!!!! - BMW Forum - BimmerWerkz.com
Old 09-21-2003, 09:07 AM   #1 (permalink)
quickmike is an unknown quantity at this point
Talking
I just bought a 91 3251 (E30) and the only problem with it was the airbag light stays on all the time. I've been looking for a reset tool, and although ive found a few on the net, they say "(except for E30 and a few other models listed)" DOHHH!!!
Anyone have any clues where i can get the tool to reset the SRS system on my E30, or possibly any tips on reseting it without an expensive tool?
Please help......I'm dying over here!!!!
Thanks in advance to anyone who can help
quickmike is offline   Reply With Quote
Old 09-21-2003, 09:11 AM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Moving to E30 section..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 09-22-2003, 09:41 AM   #3 (permalink)
EXtech's Avatar
well, there must be a reason that the light is on. I would figure that out first and foremost. Most likely (the most common issue) the crash sensor under the hood is faulty. Resetting the light isn't going to do you any favors. If you want to give it a shot, you can disconnect both battery cables and then touch the two CABLES together and hold them there for about ten seconds. Then reconnect the cables and see if your light went out. I think you'll find that the light will come right back on because something is malfunctioning in the system. I'd have it diagnosed, for safety reasons of course.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 09-22-2003, 03:49 PM   #4 (permalink)
thanks alot, I'll try that out. And youre right, safety is an issue but maybe I will be lucky.
Thanks for the response
Old 05-10-2004, 10:03 AM   #5 (permalink)
kawasabi is an unknown quantity at this point
Here is how I did it on my 91 E30
1. Buy the reset tool from handsontools.com
2. Remove knee bolster panel on drivers side and access the orange connector leading to srs control box.
2. Locate the white/voilet(TX) and white/yellow wires(RX). Splice in a set of wires long enough to reach 20 pin connector under hood.
3. Remove 20 pin connector and access the wires from behind the connector. Pin 15 is white/yellow(RX) and pin 20 is white violet(TX). Splice these two wires into the wires you have coming from the srs control box connector.
4. Put it all back together, plug the tool in and reset the light per the instructions included with the tool. Now you can reset it any time you want.
kawasabi is offline   Reply With Quote
Old 05-19-2004, 04:24 PM   #6 (permalink)
325i girl is an unknown quantity at this point
I have a question kind of on the same topic. I have a light that says I need to check my brake lights, but I've had it looked at time and time again and the guys swear that there's nothing wrong with the brake lights. So if I found a tool would it be able to get rid of that light?
325i girl is offline   Reply With Quote
Old 05-20-2004, 01:19 AM   #7 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
If your's is an E30, then no. I don't know what the newer 325's have, but with mine, the light just tells if a light bulb is burned out. In which case, if you replace the bulb, the light goes out. It may be different on an E36.
heifetz17 is offline   Reply With Quote
