Sqeaky Noise From The Rear - BMW Forum - BimmerWerkz.com
Old 10-30-2004, 11:47 PM   #1 (permalink)
javieruz's Avatar
javieruz is an unknown quantity at this point
Send a message via ICQ to javieruz Send a message via MSN to javieruz
i dont know much about the suspension part of the car, but i suppose that if i hear a lot of sqeaky noise from the back it is time to replace the CV joints?
or is just adding the grease necessary?
i guess if the joints fail, the axels may get damaged?
where to get cheap OEM joints then?
thanks.
<span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span>
javieruz is offline   Reply With Quote
Old 10-31-2004, 12:47 AM   #2 (permalink)
Cookie's Avatar
Cookie is an unknown quantity at this point
Send a message via MSN to Cookie Send a message via Yahoo to Cookie
It could be the shock mounts. Mark's car was squeaking and they were the problem.
Margarita.
Cookie is offline   Reply With Quote
Old 10-31-2004, 04:57 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I would look at the shocks, shock mouts, and rear bushings before you replace axles. The BMW rear axles hardly ever go bad.
My M50 Powered E30 Page
Old 11-01-2004, 12:36 AM   #4 (permalink)
javieruz's Avatar
[snapback]221829[/snapback]
yeah, i will try looking at the shock mounts, thats probably the problem. i guess i translated the cv joints from my language to english wrong
is it easy to replace just the shock mounts? do you need to do any alignment afterwards?? thanks
Rear suspension noise (not shock mounts) Hogfisch 3-Series (E36) 9 02-01-2011 11:04 PM
Thumping noise from rear bmw325ise 3-Series (E36) 3 10-23-2005 10:04 AM
Rear Brake Noise FoxMill M3 3-Series (E46, E90) 5 08-11-2005 03:41 PM
Rear Road Noise, Noise Gets Lauder As You Go Faste victorgallas 3-Series (E36) 17 01-29-2005 04:05 PM
