Sputtering issue in my '87 e30 - BMW Forum - BimmerWerkz.com
Old 05-21-2008, 07:58 PM   #1 (permalink)
Car: 1987 325 ES
SandiegoStemcells is on a distinguished road
Hello all!
Quick question for for all of you BMW Masters..
I just got this car and went through it, since it wasn't serviced in a looong time..
Replaced: oil, plugs (Bosch platinums); wires & cap/rotor (good ones), air/fuel filters.
Problem is it is now a little slow on starting and it hesitates from the stop.
It was running better with all of the corroded crap on it!!
Once up to speed it is fine..
Should I have put in copper core plugs?
Any advice would be greatly appreciated..
Thanks
SandiegoStemcells is offline   Reply With Quote
Old 05-21-2008, 08:12 PM   #2 (permalink)
Car: 1987 325 ES
Oh, I also replaced the O2 sensor... and the fuel pump relay...
Thanks....
Old 05-21-2008, 08:17 PM   #3 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
You may have gotten the timing off a bit if the dizzy was loose at all or if you loosened the wrong bolts... Also... check the connector to the AFM on the air box... could be corroded or you could have ripped teh bellowed intake hose when replacing the air filter... that is a very common problem if it has been sitting alot... they dry rot... check for that first. If the engine is getting air in after the afm it will run very lean.
DIRTE30 is offline   Reply With Quote
Old 05-22-2008, 12:47 PM   #4 (permalink)
Car: 85 325e 90 525I '96 328i
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
my mechanic, an actual german master technician with 30 years experience, told me only use silver plugs. Bosch. so i'd say check air to fuel mix ratio or check plugs first!!!
pinnaclebass is offline   Reply With Quote
Old 05-22-2008, 01:47 PM   #5 (permalink)
Car: 1987 325 ES
Thanks for your replies!!
One question, what the he*% is a "dizzy"?
Old 05-25-2008, 06:22 PM   #6 (permalink)
DIRTE30's Avatar
Dizzy = Distributor.
Old 05-26-2008, 02:16 AM   #7 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Lol Check for vacuum leaks Check you intake boot to they crack quite often... replace mine twice on my 325ES....
1992 318i Coupe parts car
I am Captain Obvious
Old 05-26-2008, 12:13 PM   #8 (permalink)
Car: 1987 325 ES
Thanks for your help!!
Engine Problem-Sputtering bagrok 3-Series (E36) 14 04-19-2008 08:04 PM
Hi from Japan-E30 325i Conv. issue- Knowledgeble advice sought shopcarpro New Members Check In 0 10-03-2007 03:35 AM
91 318is Sputtering Problem MLC834 3-Series (E21, E30) 3 07-06-2006 12:13 AM
Sputtering / Loss Of Power streetdreams 3-Series (E36) 9 02-18-2005 03:35 PM
Sputtering 1982 320i threeer 3-Series (E21, E30) 2 11-01-2004 11:13 AM
