Sputter when cruising at speed... - BMW Forum - BimmerWerkz.com
Old 09-26-2007, 11:39 AM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
So this is a little hard to explain, so just bear with me....
My car drives fine with no hesitation or sputtering at all when I'm either on the gas or off the gas.......the idle is, for the most part, pretty smooth. Where I'm seeing a little "sputter" is when I'm cruising at speed, I usually notice it in 3rd or 4th gear going around 35-40 (it happens in all gears but 35 is the speed limit around these parts)...It happens when I'm barely on the gas....barely enough gas to maintain the speed, that's when the "sputtering" kicks in.
Now to describe the sputter.....It's so subtle I'm pretty sure you would just think it's road conditions, but I know my car better then that....and I'm pretty sure it some sort of "something" with the car. Again, it's hard to explain....it's not a huge hesitation but just enough for me to notice. Also, it's pretty random....it's always there but it's "rhythm" is pretty random. But when I give it just a little gas, the sputter disappears....or when I let off the gas the sputter disappears again...
I got an inspection II less then 8,000 miles ago. New plug wires, new intake boot.....
any idea's??
She's an '89 325i convertible...
Thanks!
yammahamma is offline   Reply With Quote
Old 10-03-2007, 11:26 AM   #2 (permalink)
yammahamma's Avatar
Car: '01 330i
bump....
no one has any ideas?
Old 10-03-2007, 07:06 PM   #3 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
I had a leaky wire... and it did stuff like that.
Another possibility is that your injectors might be clogging up.
My BMW Blog
Old 10-03-2007, 08:10 PM   #4 (permalink)
yammahamma's Avatar
Car: '01 330i
as in plug wire?
Those are new last year....
Old 10-06-2007, 12:27 AM   #5 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
Wonderboy is on a distinguished road
I had a similar problem in my e36 m3. it turned out to be a misfire in cylinder 2. i changed the sparkplugs and problem solved... So far...
I pretty much piss excellence!
Wonderboy is offline   Reply With Quote
Old 10-18-2007, 05:59 PM   #6 (permalink)
Beemz325 is on a distinguished road
some problems ive encountered with sputtering: clogged fuel injectors or a broken head gasket. you might be leaking oil and not even know it.
Beemz325 is offline   Reply With Quote
speed over speed bumps WarNox 3-Series (E36) 10 06-24-2006 05:37 PM
Engine Stutter at high speed...HELP !!! 323iguy 3-Series (E21, E30) 6 10-13-2005 07:28 PM
cruising speed vs rpm e30e30e 3-Series (E21, E30) 3 09-19-2003 05:52 PM
