speedometer, odometer & MPG gauge - BMW Forum - BimmerWerkz.com
Old 08-25-2003, 01:07 PM   #1 (permalink)
merob247's Avatar
merob247 is an unknown quantity at this point
OK went to install my new cd player ... and when i went to go get some more stuff for it .... the speedometer didnt work ... niether did the odometer .... then i look over and my MPG gauge is goin crazy! .... any 1 kno if this might be just a loose wire or a fuse or somethin.... need this back .... i can sorta tell how fast im goin by my tachometer ... but its not to reliable .... plus i am now due for an inspection ... and it wont pass like this lol ... thanks for the help
Rob
<span style='color:red'>1985 318i</span>
Drive the straightaway as if you were to die on the turn.
<span style='color:blue'>
The Top Ten Reasons To Date a Runner
1. Most of us like to do it everydayl
2. We don't mind discussing Performance
3. The good ones have perfect strides
4. We really appreciate a good fit
5. We dont mind jumping hurdles to get to the finish
6. The more you sweat, the better you look
7. We do it anywhere
8. We prefer to do it outdoors
9. Hopefully YOU'LL be our best time and.....
10. No matter how tired we are .... we keep right on going!
</span>
&quot;Hmm... Upgrades&quot; - Neo
merob247 is offline   Reply With Quote
Old 08-25-2003, 01:17 PM   #2 (permalink)
m42technic's Avatar
m42technic is an unknown quantity at this point
Send a message via AIM to m42technic Send a message via MSN to m42technic Send a message via Yahoo to m42technic
Sounds like you messed with something whel installing your radio. Go back in and double check to make sure you didnt disconnect anything back there.
<span style='font-size:8pt;line-height:100%'>James
'91 318is</span>
m42technic is offline   Reply With Quote
Old 08-25-2003, 02:30 PM   #3 (permalink)
yeah you may have crossed a couple wires or screwed something up when putting it back together, hopefully the gauges arent broken
Old 08-26-2003, 11:41 AM   #4 (permalink)
eclypser is an unknown quantity at this point
Send a message via AIM to eclypser Send a message via MSN to eclypser Send a message via Yahoo to eclypser
I recently had mine in for A/C service and they took out the radio etc. and when they put it back together nothing worked. They had blown fuses when they were messing around back there and once I replaced the fuses then eerything but the tach and MPG worked. So maybe you should check fuses.
Had 95 M3, then 99 M3, then 01 M3,
Then I got married and bought a House.
Now I've got 89 325i and 96 328is both jet black two doors with 3 pedals.
BUT I'm working my way back up to the M.
eclypser is offline   Reply With Quote
Old 08-26-2003, 12:00 PM   #5 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
ALso check to make sure you didn't cross the dimmer wire (if there is one) with the wrong wire. That's usually in concert with the dash lights and if it was crossed (or connected to say ground or 12v+) it could cause problems like you are seeing. But check fuses first.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-27-2003, 02:42 PM   #6 (permalink)
JUSTIN_325I is an unknown quantity at this point
Send a message via AIM to JUSTIN_325I
That is funny, because my 87 325i does the same thing, no speedo, odo, or MPG...
It does kick on every now and again.. The good news is I have had the car since Decmber and only put 3000 miles on (accoring to ODO...)
JUSTIN_325I is offline   Reply With Quote
Need Carfax Report, Please Help F U Have Carfax Ac ozbmw 5-Series (E12,E28, E34, E39, E60) 2 05-11-2005 10:58 AM
Speedometer not working M5power 5-Series (E12,E28, E34, E39, E60) 9 03-29-2005 08:58 PM
