Speedometer Needle Problem - BMW Forum - BimmerWerkz.com
Old 06-30-2005, 09:40 AM   #1 (permalink)
Todd Ferrie is an unknown quantity at this point
Hello,
I'm new to the forum and need a little guidance.
I have a 1989 325i convertible. The needle on the speedometer stops working from time to time. If I tap the panel, it usually starts working again. Otherwise it just starts working for no apparent reason over time. The odometer stops when this happens as well. Does anyone know what causes this? Is there a quick fix?
Along the same lines, the light for the speedometer goes off every now and then as well. Is these problems related?
I have very limited knowledge...please advise!
Thanks!
Todd Ferrie is offline   Reply With Quote
Old 06-30-2005, 12:33 PM   #2 (permalink)
Scotsman is an unknown quantity at this point
Originally posted by Todd Ferrie@Jun 30 2005, 09:40 AM
Hello,
Thanks!
[snapback]358557[/snapback]
Does your radio still work when your speedo stops? the radio and speedo are on the same circuit in my '90 convertable, and the fuse used to vibrate loose in the engine compartment on me from time to time causing approx. the same problem.
Scotsman is offline   Reply With Quote
Old 06-30-2005, 01:09 PM   #3 (permalink)
The radio works fine.
Old 07-02-2005, 12:04 PM   #4 (permalink)
It could be the speed sensor in the diff or a dry joint in the cluster or the speedo head itself try cleaning the diff sensor first they’re easy to get to and are normally cover in swarf
E34 Speedometer Problem rml612 5-Series (E12,E28, E34, E39, E60) 2 08-26-2005 01:50 PM
Z3 Speedometer Needle Not Working djs1122 1,6,7,8 - Series and Mini Cooper 1 07-11-2005 01:49 PM
Electric Speedometer Problem Alf 5-Series (E12,E28, E34, E39, E60) 0 03-23-2005 11:30 AM
E39 1999 528i Speedometer problem vinny 5-Series (E12,E28, E34, E39, E60) 4 06-24-2004 12:30 PM
Speedometer problem Alpha 5-Series (E12,E28, E34, E39, E60) 3 06-18-2004 03:57 PM
