Speaker ohm impedance on amp - BMW Forum - BimmerWerkz.com
Old 03-26-2007, 10:43 PM   #1 (permalink)
Iceman2k12 is on a distinguished road
Send a message via AIM to Iceman2k12
I decided I wanted to run 4x 4-ohm impedance speakers (2x Kicker KS525's and 2x Polk DB525's) in parallel to the 2 channels on my 920watt Kenwood Kac-7202 amp. After drawing it out on paper, I realized that the ohm rating would actually become 2 ohms for each channel. Does this mean I will blow both of my speakers if I connect it in this way, or since the amp can handle a 2-ohm load, does this wiring schematic have no effect on the speakers? Would a series circuit be a better idea? Thanks for any advice
Iceman2k12 is offline   Reply With Quote
Old 03-27-2007, 07:42 PM   #2 (permalink)
Car: Opening soon:
It'll just sound like crap. Run your kickers through the kenwood then build your box with a divider to keep the speakers from fighting with each other. Add separate bass ports then line or fill with poly fill for less air buzz and more rounded bass.
Old 03-27-2007, 11:57 PM   #3 (permalink)
do you recommend 4 or 2 gauge amp wiring kit for the Rockford amp?
Old 03-28-2007, 12:01 AM   #4 (permalink)
Car: Opening soon:
Bigger the better I say, although 4 gauge would be plenty, just beef up both + and - sides. There have been too many times I've seen 2 gauge wire going to the amp and something much smaller on both the amp ground and battery ground. No sense beefing up one side and not expect the same for the other.
speaker size / impedance question mikester328 Audio and Electronics 8 10-27-2006 06:35 PM
2 Kicker s12l7 (2005 model)(dual 4 ohm) in custom V-shape sealed box w/ amp rack kc740i Audio/Miscellaneous Auto Parts 1 06-20-2006 05:50 PM
2 Kicker s12l7 (2005 model)(dual 4 ohm) in custom V-shape sealed box w/ amp rack kc740i Audio and Electronics 1 06-06-2006 09:13 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
Forget speaker upgrade, go for an amp Jon G. Audio and Electronics 1 11-26-2005 01:08 AM
