So I broke a rocker arm - BMW Forum - BimmerWerkz.com
Old 03-29-2004, 07:34 PM   #1 (permalink)
llll1l1ll is an unknown quantity at this point
Send a message via AIM to llll1l1ll
I've heard different things as to how to replace this rocker arm. It's on my '88 325is, the #2 piston, intake valve. The arm snapped clean in half, so theres still some arm leftover on the pivoty shaft dealy. I've heard that I would have to pull the head to fix this. Then again, my dad said the most I would need to do is take out the camshaft. The Hayne's manual says I just need to remove a tab that holds the sucker in. Anybody have a good write-up, or just flat out know and would care to explain?
Three rocker arms later and I still haven't learned my lesson!
llll1l1ll is offline   Reply With Quote
Old 03-29-2004, 07:36 PM   #2 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
well ive never done it myself and id have to go study some pictures to tell you how its done but i know to pull the cam you have to pull the head. You cant just pull the cam out the top like some 4 cylinder engines.
Fox is offline   Reply With Quote
Old 03-29-2004, 09:50 PM   #3 (permalink)
Well, hopefully I won't have to pull the cam.
Old 03-29-2004, 11:25 PM   #4 (permalink)
Some good news and bad news.
It can be done by loosening the valve adjustments and pushing the rockers of the cam lobe, then pulling the rocker shaft out the front.
The bad news is 25% will cause valve damage doing this with the head on the engine. Heck I have seen the valves bent doing this with the head on a bench.
I would suggest a real shop.
Some projects are best left to the mechanic.
Later,
&lt;img src=&quot;http://kcrealtime.com/dyno-max_900_hp.gif&quot;&gt;
KC Ron Carter is offline   Reply With Quote
Old 03-30-2004, 01:49 PM   #5 (permalink)
Damn! Looks like I have work to do!
Help, Coolant Hose Broke And Drained All My Coolan jshearer 3-Series (E36) 6 06-12-2007 11:22 AM
Control arm bushings stracer 3-Series (E36) 1 09-12-2005 04:19 PM
Valve Rocker Arm will 3-Series (E21, E30) 3 04-28-2005 12:07 AM
Eccentric Cam On Rocker Arm ae.cowboy 3-Series (E21, E30) 0 03-30-2005 08:51 PM
Rocker arm llll1l1ll 3-Series (E21, E30) 3 03-26-2004 04:21 PM
