Slow to start - gas smell - BMW Forum - BimmerWerkz.com
Old 10-31-2005, 04:30 PM   #1 (permalink)
irish is an unknown quantity at this point
Question Slow to start - gas smell
I have had my 325ic sitting up for about two weeks ...when I started it the other day it took longer to start (three or four seconds cranking) than usual and I smelled gas just after it started ........ later, the same day, after it sat for about 2 hours, the same thing happened ...about three or four seconds cranking and a gas smell as soon as it started....any idea what could be the cause?
Thanks,
Irish
irish is offline   Reply With Quote
Old 10-31-2005, 06:14 PM   #2 (permalink)
Scotsman is an unknown quantity at this point
check out your fuel filter and / or fuel lines first. my thinking is that the extra time spent turning over is the lines taking more time to build pressure because of a leak somewhere, which would also attribute to your gas smell.
Scotsman is offline   Reply With Quote
Old 11-01-2005, 02:42 PM   #3 (permalink)
Smell Gas
Take a look at the fuel lines under hood and the vacumn line to fuel pressure regulator. The rubber on these fuel lines gets old and will after a long time crack, I had a leak just aft of drivers door and found a small crack in molded hose uo and under her and near fuel tank.
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 01:41 PM
gasoline smell after filling up SD318is 3-Series (E36) 1 10-29-2005 08:21 PM
Funky Air Conditioning Smell & Dog Smell rsn48 Wash & Detail 3 10-19-2004 05:27 PM
Slow start Mykemwai 3-Series (E21, E30) 1 06-29-2004 06:00 AM
