Short Shift Conversion - BMW Forum - BimmerWerkz.com
Old 04-04-2005, 02:01 PM   #1 (permalink)
tomsbmw325is is an unknown quantity at this point
How much does it usually cost for Short Shift conversion?
Parts and Labor.
tomsbmw325is is offline   Reply With Quote
Old 04-04-2005, 02:18 PM   #2 (permalink)
DJProfessor's Avatar
DJProfessor is an unknown quantity at this point
there's a cheap conversion out there for 30 bones (or so i got mine with my discount, so it may be a bit more, still cheap).......you use the shifter out of a Z3.....i did it in mine. some tech found that out where i worked. works on my E21, and he had it on his E30 M.......it isn't adjustable like the BMP one, but for a quarter of the cost i will gladly live without the adjustability factor.......i will run down the part number for it.......figure on probably like an hour/hour and a half to install
sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
DJProfessor is offline   Reply With Quote
Old 04-04-2005, 04:34 PM   #3 (permalink)
Do you mean that labor should cost only $30?
How much does part ususally cost?
Old 04-04-2005, 04:44 PM   #4 (permalink)
no, the labor will be whatever the shop will charge you........and to swap that out will probably be an hour to an hour and a half......so possibly a couple of hundo depending on how much the shop charges hourly
the Z3 shifter piece set me back like 30 bucks, but keep in mind that was with my dealer discount......
Old 04-04-2005, 04:51 PM   #5 (permalink)
I got a quote for $165 part and labor, is that good?
Old 04-04-2005, 05:07 PM   #6 (permalink)
figure about 65 for the part and 100 for the labor, not bad......
go check out www.bmpdesign.com and you will probably feel much better, theirs goes for more than what you would be paying for the shifter and installation....
PS......which z3 shifter you go with? if i remember correctly it could be like one of a few that works.....but i don't remember exactly used
Old 04-05-2005, 12:16 PM   #7 (permalink)
WHAT IS A GOOD BRAND OF SHORT SHIFTER FOR E30s?
Short Throw Shift Kit 2000BMW323i 3-Series (E46, E90) 0 06-07-2005 05:08 PM
Short Shift CiscoKid 3-Series (E36) 12 12-31-2004 01:28 PM
Loose Stick shield 3-Series (E21, E30) 6 09-02-2004 05:34 PM
Who has a short shift kit?? whamman 3-Series (E36) 11 06-21-2004 07:33 PM
