Semi M3 Conversion - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 03-12-2004, 09:35 PM Thread Starter
Mr.BMW is an unknown quantity at this point
I want to do some minor M3 conversionononons to my 1990 325i E30. Nothing engine based, no, it's all body/suspension based, yes! I know generally seeing how the E30 is the chassis for both 1990 M3s and 325is general body work (front/rear/chin spoilers) is easy and can be done to make my 325i look more agressive like the sexy M3. However, I'm not a ricer, so i can give a shit about looks. I want handling of the M3. I read in a previous post it's possible to use M3 springs on a 325i. So if this is true, and I can basically turn the suspension system of my 325i to an M3's; what peices do i absoultely need, and should change from my 325i? Should I just tear the entire suspension system from it now, and replace with the M3's setup, or are there just certain components I can easily add to save me money and headaches?
Mr.BMW is offline
post #2 of 3 (permalink) Old 03-12-2004, 11:01 PM
BMWJNKY's Avatar
BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute
There may be more pieces than this but as far as I know this is what needs to be changed.
Control arm bushings, sway bars front and rear, sway bar bushings front and rear, front strut inserts, rear shocks, front springs, rear springs, rear sway bar reinforcement added. While you have the rear shocks out this would be a good time to replace the upper shock mounts with either solid or poly ones depending on how agressive you want to go. You should also upgrade your brakes too. I'd go with some slotted or cross-drilled rotors and a good agressive pad. I would also put a strut brace on the front.
BMWJNKY is offline
post #3 of 3 (permalink) Old 03-13-2004, 01:52 AM
the 325 and M3 share very few external body panels, you would have to change everything except the side mirrors, doors, and gas cap. not worth it, buy a M3 if you have to have the M3 look. as for the suspension, the M3's suspension really isnt that glamorous, its still very good, but you could do better without spending much more. instead of getting M3 shocks and springs, go with aftermarket parts such as H&R and Koni, and (if you want the responsiveness of the M3) go with the E36 M3 steering rack over e30 m3's. if you go all out and put in the M3 front strut assembly, including brakes, and the M3 rear trailing arms you'd be left with a 5lug setup, and it would give you a good opprotunity to weld the front M3 sway bar mounts up front. other things include the offset control arm bushings and alluminum control arms. then there's the extra's like a strut brace, billet Al rear shock mounts, and shock tower reinforcement plates.
MrM3 is offline
which engine is easier to mod for the E21? AE101 3-Series (E21, E30) 5 04-01-2004 08:43 AM
Completed my Valeo to Bosch alternator conversion MOTRSPRT 3-Series (E36) 5 01-26-2004 07:16 PM
Early vs. late 320i compatibility babzenuda 3-Series (E21, E30) 4 01-10-2004 03:32 AM
5 SPeed Swap PLEASe HELp ME nukeall 3-Series (E21, E30) 1 12-11-2003 12:36 PM
E36 front conversion to M3 wilgtr 3-Series (E36) 4 11-27-2003 05:32 PM
