Running rough - BMW Forum - BimmerWerkz.com
Old 11-30-2007, 09:31 AM   #1 (permalink)
bagelboy91's Avatar
Car: 91 318is
bagelboy91 is on a distinguished road
Running rough
SO i changed out the valve cover gasket due to leaking oil, and now my ride runs rough...real rough. Changed plugs today, check plug wire conections...but NG.
any thoughts?
BagelBoy91
1991 318is
bagelboy91 is offline   Reply With Quote
Old 11-30-2007, 10:22 AM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
vacuum leak is what it sounds like, did you disconnect any vacuum lines or anything in the process? Also make sure theres no leaks between the AFM and the intake manifold...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 11-30-2007, 12:59 PM   #3 (permalink)
bagelboy91's Avatar
Car: 91 318is
Just disconnected the one that comes off the valve cover...and runs under the manifold. I did notice there was a gooey oil like substance at the connector.
Funny...i took it for a spin around the block following the valve cover gasket change...all was well. Took it out a few days later to go to the store....started running rough, so i went home.
BagelBoy91
1991 318is
Old 12-01-2007, 12:07 AM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
is it like 1 cyl. is misfiring? or just not as smooth as normal?
1992 318i Coupe parts car
I am Captain Obvious
Old 12-01-2007, 10:05 PM   #5 (permalink)
bagelboy91's Avatar
Car: 91 318is
thats what it seems like....
BagelBoy91
1991 318is
Old 12-01-2007, 10:43 PM   #6 (permalink)
could be a ignition issue... clean all your conncetions from the coil to the plug and check your plugs too..
also to see which cyl. is missing. unplug one at a time and if idle drops then that cyl. is working JUST BE WARNED you can get shocked... it isn't that bad it is just scary the first time it happens
Old 12-04-2007, 07:46 PM   #7 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
When you say "runs rough"... do you mean at idle or under throttle? If it's only under idle... I'd check your crank case ventilation system... you could have knocked somthing loose inside the baffle under the cover and blocked off the outlet. Or... you could have dislodged something inside some of the hoses that run to your IAC motor and gotten them lodged inside the IAC motor causing your rough idle. If you removed your plug wires to do the valve cover gasket... I would ohm out the wires, should be 6k ohms or less per linear foot of wire. Flex em around while you test them to see how the reading changes. Another thought ... how long was the car sitting while you did this? If it sat for longer than it would normally, you could have developed a little corrosion inside your distributor cap. This has happened to countless old Bosch caps... they run forever on the original cap without any probs untill they are allowed to sit for a stretch and once the car warms up and the mixture leans out... bada boom, she don't wanna run.
DIRTE30 is offline   Reply With Quote
Old 12-05-2007, 12:56 AM   #8 (permalink)
^ didnt know that and now I do thx how long does the car to have to sit?
Old 12-08-2007, 07:05 PM   #9 (permalink)
DIRTE30's Avatar
Depends on the weather... the moisture level will affect that. More moisture = less time.
Old 12-08-2007, 11:57 PM   #10 (permalink)
^ thx love the drunken kitty BTW
any update Bagel??
Old 12-09-2007, 12:40 PM   #11 (permalink)
bagelboy91's Avatar
Car: 91 318is
any update Bagel??
Thanks for the help.....wires it was. New set installed this morning....running smooth again.
BagelBoy91
1991 318is
Old 12-10-2007, 01:03 AM   #12 (permalink)
^ great to hear!
e34 525i running rough... cold weather? d3ity 5-Series (E12,E28, E34, E39, E60) 3 11-12-2007 09:35 PM
E39 528i/5 sport temporary rough running Teh Prof 5-Series (E12,E28, E34, E39, E60) 0 05-23-2006 09:31 PM
Car running rough, ground strap question 94325is 3-Series (E36) 5 11-22-2005 01:39 PM
E30 Running rough in 4th and 5th only cdruve 3-Series (E21, E30) 3 09-03-2004 06:27 AM
rough running and no idea why.. mdaitc 3-Series (E21, E30) 1 06-19-2004 05:28 PM
