Running problem with an '85 325e. Help? - BMW Forum - BimmerWerkz.com
Old 08-07-2007, 06:39 PM   #1 (permalink)
StoneyBlouse is on a distinguished road
Question Running problem with an '85 325e. Help?
Ok, the project. 1985 BMW 325e.
Starts great usually and you can run it for a half hour or 5 minutes. Shut it off and suddenly it may or may not fire back up.
It it does fire you can run it twenty minutes or so, shut it off and it will crank over and fire with the pedal down for awhile and it will run terribly for awhile before simple dying.
Any ideas?
It sputters and tries to start when you turn the key and will keep firing if you keep on the starter.
However the second you let the key return to run from start it dies.
I'm stumped. Please help me out if you can! Anything is appreciated.
<img src="http://i48.photobucket.com/albums/f231/StoneyBlouse/Scirocco_Comp.jpg">
1981 1.8l VW Scirocco-Auto-X Constant Project
1985 BMW 325e-Every Day Ride (Fiances Car)
1988 Subaru GL Wagon-Off Road Project
????- Truck For Every Day Use
StoneyBlouse is offline   Reply With Quote
Old 08-08-2007, 12:11 AM   #2 (permalink)
Car: Opening soon:
Test your coolant temp sensor when hot. Or just replace it (about 20 bucks or less)
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
Power Steering Problem! Help Needed! BMWstealth 3-Series (E46, E90) 3 03-28-2006 07:37 PM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 10:07 PM
86 325e engine swap to 91i idle problem lemonhead 3-Series (E21, E30) 10 02-21-2006 06:05 PM
Drl Headlamp Relay Problem (daytime Running Light) tonyhon 3-Series (E36) 5 01-18-2005 07:42 PM
