Running, but not starting - BMW Forum - BimmerWerkz.com
Old 09-07-2011, 03:09 PM   #1 (permalink)
mystical beemer's Avatar
Car: '87 BMW 325i (e30)
mystical beemer is on a distinguished road
Hi all,
New to the site, I have been trying to find a solution to my particular problem on the internet but to no avail............
So am trying this medium to see if I can get some answers on here.
Right then,will try and keep it simple~
I have a 1987 BMW 325i (e30) my problem is that the car will not start by turning the key in the ignition(although it will turn over and wants to start)
It can be pushed and will bump start,and keep running but when you turn off the engine and try to restart with the key my baby says noooooooooooo.
M B
mystical beemer is offline   Reply With Quote
Old 09-08-2011, 05:34 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
What shape is the battery in? If you connect it to a known good battery or a heavy duty jump starting kit, will it start then?
If you put your lights on when you try cranking it over, do the lights dim dramatically?
Once its running, does it idle and rev ok, even with the high beam & AC on?
Riding in style
Old 09-08-2011, 08:28 AM   #3 (permalink)
Battery was a brand new 1, 7 or 8 months back.
Haven't tried heavy duty cables,(none readily available),also figured that with it turning over the battery is good.
Didn't try lights as it was in daytime when I got it running by bump start.
AC works fine as do the leccy mirrors and stereo... admittedly I hadn't or didn't consider the charge in the battery
when she was running she sounded ok, but to the 'trained ear' the idling tickover was dipping and rising very slightly.
hope this helps
Old 09-08-2011, 01:39 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Does the starter spin freely or would you say "Not as I would like it to" ?
Does your E30 have an ECU or Dizzy?
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 09-08-2011, 01:46 PM   #5 (permalink)
dj_rookie is on a distinguished road
what is the battery kicking in volts without engine running? it should be around 12 v... then bump start it or whatever you need to do to get it running and check with the engine running.... it should be at around 13.5v giive or take about .3-4v... it may be your battery and/or it may be your alternator.... also check all of your fuses
dj_rookie is offline   Reply With Quote
Old 09-08-2011, 01:47 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Good answer DJ, missed that one lol
Eso es todo!
BMW Part Market
New Member ?
Old 09-08-2011, 01:51 PM   #7 (permalink)
cheers dabsy, was just trying to help with a bit of common sence lol. im sure you thought of it, but didnt mention lol
Old 09-08-2011, 01:56 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Yeah, I was working from the ground up lol
Eso es todo!
BMW Part Market
New Member ?
Old 09-08-2011, 05:33 PM   #9 (permalink)
Non running @ 12v, will bump again tomoz and re-check whilst running,all fuses have been checked and are good.
thanks for info/ideas:
Alternator,battery voltage running/not running
Old 09-08-2011, 05:36 PM   #10 (permalink)
spins freely...........
An ecu last 3 digits 173, replaced this when I first got the car
Old 09-09-2011, 02:07 PM   #11 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Does it match your chassis number?
The LAST five digits need to match or it will be a donor and the key may not be programmed to it !!
Otherwise, it could be an air lock in the fuel line as the starter won't turn it over as quick as a bump-start...
Try purging the injector rail using the valve then try starting with key!
Eso es todo!
BMW Part Market
New Member ?
520i E34 starting / running problems buxted69 5-Series (E12,E28, E34, E39, E60) 2 05-18-2010 04:40 AM
89 535i suddenly not starting and yet has a motor running while shut down. nothingthatcantbedone 5-Series (E12,E28, E34, E39, E60) 4 11-03-2008 06:34 PM
Its Running Hot htp.bmw 3-Series (E21, E30) 8 09-19-2005 04:20 PM
Running Rca's To Amp phathaway Audio and Electronics 4 03-17-2005 01:00 PM
How do you know if it's running too hot?? sparticus 3-Series (E21, E30) 3 06-27-2004 12:13 AM
