Originally Posted by triggrhaapi Seriously, most problems related to idle on M20s and M10s can be at least partially solved with a simple valve adjustment. |
id have to compleeeeeeeeeeeetely disagree with you here...most idle problems with M20s have to do with the idle valve...
Glad to hear the intake boot solved the problem, usually does when its leaking between the AFM and engine...
