Rocker arm - BMW Forum - BimmerWerkz.com
Old 03-25-2004, 09:15 PM   #1 (permalink)
llll1l1ll is an unknown quantity at this point
Send a message via AIM to llll1l1ll
My dad says I should just replace the rocker arm. Well, that's obvious. But the thing is, my engine has well over 200k on it. I like to drive spiritedly, and I know something else is bound to happen with some of the other cylinders. I'm thinking I'm just going to replace the rocker arm, and then buy a new/rebuilt engine. That seems like the best idea at the moment. Because, I really don't want to keep dumping money in the engine if its going to break down again and again. I'd rather spend 700 for a used one with 88k on the clock, rather than spend 1.20 each week for a quart of oil, and a periodic 70 or 80 dollars a month on fixing some random thing that broke. My car-as a body-already has enough problems as it is. I'd almost like to get a whole new E30, but that would require a bit too much work. I know of a place that can get me a cheap engine. My dad won't like it, and nor will my mom. I, however, feel its the best decision, considering as how I've paid for the entire car, and every problem... including the fuse my dad blew.
Three rocker arms later and I still haven't learned my lesson!
llll1l1ll is offline   Reply With Quote
Old 03-25-2004, 10:16 PM   #2 (permalink)
flipsgonetopless's Avatar
Car: 1991 318is
flipsgonetopless is an unknown quantity at this point
Send a message via MSN to flipsgonetopless
Well let me tell you that replacing the whole enigine is kind of a tricky and tidious work, I just replaced the engine on my 89 e30... the thing I fucked up on was removing the engine with the Torque Converter still on the block. You have to remove the converter before you remove the engine, also the bolts that that hole the tranny to the block are star head bolts so be prepared for that. I got under the car with my metric tools and to my surprise , the only thing I can tell you is make sure the torque converter is still in tact with the tranny or you will break the hydrolic pump on the tranny and there goes that... another tranny. Well if there are any more questions just ask and what ever I can help you with (advice and such) just ask. B)
flipsgonetopless is offline   Reply With Quote
Old 03-26-2004, 04:36 AM   #3 (permalink)
toffa182 is an unknown quantity at this point
you can actually take out the engine without removing the gearbox. just lift the front of the car, remove radiator, loosen all the mounts, flip the rear end of the engine/gearbox package down and lift the engine out. voilá!
toffa182 is offline   Reply With Quote
Old 03-26-2004, 04:21 PM   #4 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
Automatic transmissions are longer, not saying it cant be done but that its different from a manual gear box.
Keep the engine. Fix the rocker. Wear the crap out of the car. Its worth it. If you keep the car for a year or two its well worth the money you spent for it. And really i can tell you just got the car kinda because thats what happens when you get a used car. Everything breaks at the same time and piles up on you. It seems like the car is a piece of junk. But once you get those few things fixed nothing goes wrong for a long time and still thats minor stuff.
Fox is offline   Reply With Quote
Control arm bushings stracer 3-Series (E36) 1 09-12-2005 04:19 PM
Valve Rocker Arm will 3-Series (E21, E30) 3 04-28-2005 12:07 AM
Eccentric Cam On Rocker Arm ae.cowboy 3-Series (E21, E30) 0 03-30-2005 08:51 PM
Hartge Rocker Cover For Early 6 Series BMWL2 Classifieds Sell & Buy 0 03-20-2005 07:39 PM
So I broke a rocker arm llll1l1ll 3-Series (E21, E30) 4 03-30-2004 01:49 PM
