hey guys i drive an 86 325 and i've had the car for about 2 years now. when i first had it inspected it passed with no problems at all, well now it is inspection time again and i noticed a few weeks ago that my reverse lights do not come on. the bulbs are brand new and all the other tail lights work. at first i thought it could be the neutral safety switch, is that the problem? help appreciated
I've got a short somewhere between the shifter and the switch on the tranny.....currently my reverse lights work.....they didn't for a while....when I get around to it I'm going to replace the wiring from the shifter down....
^^^ I would test to see if power is getting to the switch before you commit yourself to a change......in my case the wiring going to the switch is bad....I've heard alot of times the connectors on the switch just need to be secured better....
test for power, make sure the wires have good contact...and if you need to replace the switch...
Before you go jacking up your car and causing yourself a lot of unnecessary drama, do this first: Pull up your shift boot, in there you'll find a white two wire connector, two of these wires go through the lower shifter boot. This is your back up switch circuit, unplug and test with an ohm meter, with the trans in reverse you should have continuity between the terminals that go into the boot. On the other end you should have 12V on one of the terminals with the key in the "run" position. If you do have 12V, bridge the terminals and your reverse light should light up. If not you have other problems than the switch.
P.S. I have found that this wire gets pinched if the trans is ever lowered, often times blowing the fuse, also killing the blower motor and gauges…
i had my clutch changed a few thousand miles ago, the guy who did it said there were a bunch of frayed wires by my transmission but he repaired them. unfortunantly i dont know how long my reverse lights havent been working
