reverse lights... - BMW Forum - BimmerWerkz.com
Old 07-14-2006, 02:54 PM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
reverse lights...
my reverse lights have worked on and off for the past couple years until they finally just don't work at all now.
I had my mechanic test to see if power is getting to the switch on the tranny and he said that no power is even getting to the switch, so there must be a short or something somewhere....are there some common places to check?
I don't really want to pay my dude $80 and hour to find it....
thanks!!
yammahamma is offline   Reply With Quote
Old 07-14-2006, 07:27 PM   #2 (permalink)
Car: Opening soon:
Pull the shift boot, in there you'll see two wires that go through the shift boot, make sure it's not pinched in there (happens often when the trans mount is dropped) If not follow it to a white plug, pull it apart and test for 12V. This plug get cruddy often.
Not to ask stupid questions, but it is a manual right?
Old 07-15-2006, 01:06 PM   #3 (permalink)
yammahamma's Avatar
Car: '01 330i
Yes, manual.
I've looked in there before, but I only remeber one wire going in through the rubber boot. Maybe both wires are inside the same "casing"??
When you say "If not follow it to a white plug" do you mean follow them toward the engine or follow them down through the boot?
thanks!
p.s. I don't get my car back until monday so I can't check until then...
Old 07-15-2006, 04:17 PM   #4 (permalink)
Car: Opening soon:
From the boot inside where the shifer is in the console, from there it goes to a plug then it goes down to the floor just before the drivers seat then across to the main harness.
Reverse Lights yammahamma 3-Series (E21, E30) 2 06-18-2005 05:18 PM
E30 325ic - Reverse Lights Not Working ///Matt 3-Series (E21, E30) 1 01-10-2005 04:02 PM
Intermittent Reverse Lights Issue cleansdabaffroom 5-Series (E12,E28, E34, E39, E60) 5 01-10-2005 11:35 AM
reverse lights suddenly stoped working mstar 3-Series (E36) 5 05-28-2004 06:16 PM
Reverse lights on my moms car 2.link 3-Series (E46, E90) 4 01-10-2004 11:53 AM
