More specifically, when I turn the key to start, there's a very rapid clackclackclackclack until i stop turning the key. There's an audible metallic ring when I stop. The usual startup sounds are absent.
The dashboard lights are on when i turn the key, the radio turns on with the antenna raising itself, the headlights work though it dims slightly when i turn the key. Signal lights, brake lights, power windows all work.
Has anyone seen the problem symptoms before? Greatly appreciate any help.
you gotta understand how many amps a starter motor draws....tremendous, in fact, that is basically all the battery is there for, to engage the starter/solenoid motor, after the engine is running the car runs off of the altenator. the battery then is recharged via the altenator. 12 volts but the altenator puts out like 14.5 volts.....the extra 2.5 volts are there to recharge the discharged battery back to proper charge (amperage). Back in the day they had generators and regulators. If the regulator failed the generator would overcharge the battery and cause it to explode. The altenator addressed that issue. Truth, if the engine is actually running you can remove the battery altogether, done properly and the car won't even die.
Well, in reply to you both, I'll take a look at the battery first as it sounds the easiest to remedy/check. Will post back here again if the problem still can't be resolved, maybe with a video (if this forum allows links). Thanks a lot everyone.
the car will die eventually if the battery is unhooked or atleast mine did when I first bought it she had a bad battery that barely held a charge, replaced the battery and no more dieing
Hi guys, it really was just a flat battery. Temporarily fixed for now. Thanks for the help.
*cough* *cough*
1992 318i Coupe parts car
Heh, would you guys look at me strange if i told you that I haven't driven the 325e past 2000 rpms? The highest speed I've ever driven the car is 100km/h (just at 2000rpm)
The guy that helped me with jump starting the car said that the alternator works best at revs between 2000 and 3000 rpm. Is there any truth to that?
