Replacement Storage Partition Doesn't Fit? - BMW Forum - BimmerWerkz.com
Old 04-08-2007, 06:34 AM   #1 (permalink)
snpower is an unknown quantity at this point
Question Replacement Storage Partition Doesn't Fit?
I recently bought a new storage partition of off Ebay to replace mine which is cracking. After checking the listing to make sure it would fit a '90 325ic I figured I was good to go. Once it arrived, and I pulled the old one out, it was quickly evident that the two are not the same. The difference is in the area of molding about half-way down the driver's side, as you can tell from the photo (the replacement part is the top one). I can only assume that since my car is air-bagged and there is a piece of metal in that area that I needed a different part #; I did not see any differentiation when I checked the parts catalog though.
snpower is offline   Reply With Quote
Old 04-08-2007, 09:28 PM   #2 (permalink)
Car: Opening soon:
That one is from around the 86 or older with out the metal knee bolster. If it's from a manual 2D I'd be interested in it if you don't want it.
Old 04-09-2007, 05:14 AM   #3 (permalink)
I took a band saw and modified the side on the newer piece to match my old one. The cut isnot visible once everything is installed under the dash.
Great info, I appreciate it. Just because the the auction says it will fit your vehicle, doesn't always make it so!
OEM M3 RIMS...FIT 325xi???????? NoBa 3-Series (E46, E90) 16 07-13-2006 04:15 PM
BMW ashtray replacement storage unit 4 sale !!! joebimmer318i Aftermarket Parts 7 07-07-2006 11:52 PM
Brake Fluid Replacement BMW328 3-Series (E36) 2 04-07-2006 02:17 PM
e30 m3 springs fit 89 325ic? xalier 3-Series (E21, E30) 3 04-05-2006 01:13 PM
Replacement Exhaust System Leo J. DeLeon 1,6,7,8 - Series and Mini Cooper 1 07-08-2005 02:45 AM
