Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-16-2005, 02:57 PM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '89 325i convertible
Photos: 0
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
So the dorks at a local lube shop put my oil drain plug in too tight and stripped out the pan.....now I'm trying to find a oversized repair plug to fix it and checker or autozone don't carry it...and I live hours away from any BMW shop...
Where could I find a repair plug? I can't find it online so maybe I'm not calling it the right name....
help?
yammahamma is offline   Reply With Quote
Old 08-17-2005, 07:06 PM   #2 (permalink)
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
help?
[snapback]369982[/snapback]
are you SURE its the pan thats stripped and not the bolt? the bolt breaks more often then the pan.
if you need to re-tap the pan use a US standard 1/2" -20 tap, its the equivalent to 12.7mm which should be just enough to re-thread the pan. A 1/2 drain plug should be readily available anywhere..
If you want to stay metric you can drill and tap it using a m13x1.5 tap and buy a m13x1.5 bolt from homedepot, buy the tap from harbor freight tools.
When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
Old 08-18-2005, 10:30 AM   #3 (permalink)
77th Gear Member
325eXTATIC's Avatar
Photos: 0
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
Nukeduster is correct (AS USUAL) however, I will just add a word of warning... If you DO tap the pan, MAKE SURE TO CLEAN OUT ALL SHAVINGS!!! Get a good rare earth magnet, stick it to something like a coat hanger or the like (something that you can bend at 90 degrees to get inside the pan after you have tapped it) and let that bugger pick up the big stuff, then go back and stick a rag around your finger, and wipe the area around the hole clean, inside and out!!
Just looking out for ya!
Josh W
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
Old 08-19-2005, 10:26 AM   #4 (permalink)
nukeduster's Avatar
Photos: 0
or just flush them out by pouring the used oil you just drained through the oil fill port while the drain plug is still off and it will flush the shavings out.
if you have some small ones still in there I wouldnt worry too much, thats what the oil pickup screen and oil filters are for, so things that accumulate in the pan dont get picked up into the galleys.
-Dick Marcinko
Old 08-19-2005, 10:42 AM   #5 (permalink)
77th Gear Member
325eXTATIC's Avatar
Photos: 0
[snapback]370866[/snapback]
LOL, Always got a better (and easier) answer don't you!
Good Job! Someday I hope to attain the level of Master... Someday!
Josh W.
Old 08-19-2005, 11:30 AM   #6 (permalink)
nukeduster's Avatar
Photos: 0
-Dick Marcinko
vB code is On
New Spark Plug Wires For All You E30er's(Bavauto Plug Wires) Bmw1990 Product Reviews 1 09-08-2005 04:31 AM
Bmw Suspension Repair Estimate emr0591 3-Series (E46, E90) 0 11-10-2004 08:31 AM
Repair Manual For 528i mnguyen11111 5-Series (E12,E28, E34, E39, E60) 1 10-27-2004 06:47 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
